Vibration at the steering wheel around 65-75 mph ? - JeepForum.com
post #1 of 23 Old 12-13-2012, 02:38 PM Thread Starter
harricharan
Sometime I feel a vibration at the steering wheel when going 65-75 MPH , Suspension component are good tight. what can be causing this vibration any suggest ? engine mounts maybe ?
2000 Jeep Gr Cherokee 2wd 154,012 miles
harricharan is offline
post #2 of 23 Old 12-13-2012, 02:40 PM
ChrisHager
Administrator
ChrisHager's Avatar
What condition are your tires in? Sounds like they are out of balance to me.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline
post #3 of 23 Old 12-13-2012, 02:43 PM Thread Starter
harricharan
they are not new or worn out they are in between , Last time it got balance was back in 2010
post #4 of 23 Old 12-13-2012, 02:47 PM
ChrisHager
Administrator
ChrisHager's Avatar
I'd have them rebalanced.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #5 of 23 Old 12-13-2012, 03:04 PM Thread Starter
harricharan
A tire out of balance act like this and how often you should get balance ? I don't want to spend money on things i don't need .
post #6 of 23 Old 12-13-2012, 03:19 PM
doityourselfMM
doityourselfMM's Avatar
Which Calipers does your 2000 have? I went thru 3 sets of rotors on my '99before I replaced the original calipers with the newer style replacements. The old style was prone to rotor warpage.
Just a possibility.
doityourselfMM is offline
post #7 of 23 Old 12-13-2012, 03:22 PM
ChrisHager
Administrator
ChrisHager's Avatar
That could be the case if he was braking at 65-75 MPH or if his brakes are dragging enough to cause the vibration. Most likely, the tires need balanced - especially if it has been 2 years since they've been done.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #8 of 23 Old 12-13-2012, 03:55 PM
doityourselfMM
Tires would be the simple and cheap fix. Hopefully that is all it is. My experience was definately the calipers. I think the original ones were Teves or ATE. Jeep used them on the 99-03 WJs, I think. They had the big spring clips. The replacements are Akebonos. Very solid. No warped rotors. They weren't a 1 for 1 replacement, but required different mounting brackets. Just an FYI.
post #9 of 23 Old 12-13-2012, 04:34 PM
pinky2252s
They started putting the akebono's on stock WJ's in mid 01'. Just clearing it up!
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #10 of 23 Old 12-13-2012, 04:43 PM
Burgy
If you can drive through it, ie it stops when you do 80-90mph, then it certainly wheels that need rebalancing. Wheels can throw a weight which will cause them to be ou of balance, also kerbing the tyres can cause the wheels to go out of balance.
Burgy is offline
post #11 of 23 Old 12-13-2012, 04:44 PM
maloj2003wj
2006 WK
I had the same issue once... Got them balanced and everything went away. if you drive on bad roads like here in NY its common for the small little weights that tire places put on fall off when you hit bumps at high speed.
2006 WK LIMITED|5.7 HEMI
maloj2003wj is offline
post #12 of 23 Old 12-13-2012, 04:51 PM
doityourselfMM
No sweat. Thank You!
post #13 of 23 Old 12-13-2012, 04:57 PM
shockracer
You asked how often they should be imbalanced?
It's a good idea to have them balanced when they are rotated, around every other oil change.
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
Colorado Jeep Club Member #262
shockracer is offline
post #14 of 23 Old 12-13-2012, 06:53 PM Thread Starter
harricharan
Just a possibility.
Brake are okay stop smooth
post #15 of 23 Old 12-13-2012, 07:00 PM
doityourselfMM
As all others mentioned, go for a balancing. Since we don't know (yet) what the issue is, I always like to toss out all possibilities. Thus, warped rotors. I know they kicked my arse!!!
