Vibration at Speed - JeepForum.com
post #1 of 4 Old 03-03-2014, 11:27 AM Thread Starter
bobknott
Vibration at Speed
Hi All
Driving home tonight I experienced some very noticeable vibration when doing 50mph & above. Below 30mph nothing noticeable. My initial suspicions are wheel balance (ie lost weight) or engine mount. Any other ideas?
bobknott is offline
post #2 of 4 Old 03-03-2014, 11:58 AM
pat85
You could have lost a wheel weight. Check to make sure that your wheels are full of s**t (snow/ice or mud depending on where you are in the world). You could have also broken a belt in one of the tires. That's a little harder to check for if you never seen it before. Look for irregularites in the tread, like a buldge or something of the sort.
If it works, it works...do it for you.
His: 01 WJ Storm Trooper
Hers: 14 FDII Patriot
Sold: 98 ZJ
pat85 is offline
post #3 of 4 Old 03-03-2014, 12:01 PM
grussell
I would check your front driveshaft too. I experienced this last weekend and the cv joint at the transfer case was locked up. When I pulled it off I found the boot was torn allowing crap into the inside.
2001 GC Laredo 4.0 4x4 - Black l 2001 GC Laredo 4.0 4x4 - Silver
grussell is offline
post #4 of 4 Old 03-14-2014, 12:58 PM Thread Starter
bobknott
Turned out to be low transmission fluid. She had the crank case seal replaced last year & the garage did a crap job for their 950. Back she goes asap
bobknott is offline
