Vibration..really bad - JeepForum.com
post #1 of 12 Old 05-13-2013, 05:18 AM Thread Starter
GRAND_WJ
Well time to fix the vibration in my wj for good... I have the IRO single double driveshaft in my wj and all other info in sig..
Doesn't matter what adjustment I set the castor to vibration never goes away...been there from day one, its not just a simple hum but it vibrates like crazy especially when on sitting on the highway. But only there when I'm on the gas, if I release it its practically not there, so quite...
Should also add when in low range I hear click click click click the faster I go the clicker it gets. sounds like every rotation it clicks...
Ideas anyone?
Thanks
'01 WJ Limited, 4.7v8 QT2, VSI LPG, snorkle, 8" lift, HD tie rod, HD crossmember, tom woods custom double/double drive shafts, LA front/rear, bilsteins, 35 12.5 hankook muddies on 17x9 MT sidebiters, ARB frontbar, 12000 pound winch, full recovery bag, on board air, XXX 220 spot lights, rola roof rack and Notch custom flares (Iceland flares) ...
GRAND_WJ is offline
post #2 of 12 Old 05-13-2013, 06:08 AM
texlurch
Is the pinion pointing at the driveshaft? And the double cardan end is on the T-case, correct?
Forget the caster; only cure for bad vibes is to put the pinion angle right.
Mines about 2 deg off right now and I get an ever so slight very minor hum at 85 or so.
I'll be rotating the C's soon to put it all right.
Just another old fart in a Jeep... watchout younguns!!!
RC LA, IRO 6 in springs, OTK, Bilsteins, Aussie, Eaton, RCV's, 242-SYE, hidden winch, JCR Stage 3, skidded and trussed & sleeved
Colorado Jeep Club Member #383
texlurch is offline
post #3 of 12 Old 05-13-2013, 08:09 AM
MuddyWJ
How old are the ujoints?
MuddyWJ is offline
post #4 of 12 Old 05-13-2013, 10:51 AM
skain8
skain8's Avatar
Are you positive the driveline vibrations are sourced from the front, and not the rear, or a combination of front & rear? At 8" lift, you really need to be thinkin SYE, if you don't have one already.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #5 of 12 Old 05-14-2013, 03:17 AM Thread Starter
GRAND_WJ
Driveshaft is on correct, this has been an issue from day one... All vibrations are from the front, all disappear when driveshaft is removed... Would I need a double double?
GRAND_WJ is offline
post #6 of 12 Old 05-14-2013, 03:24 AM
MadderThanMax
Suggesting its your TC that's causing it.. does it sound roaring or growly when in gear?
MadderThanMax is offline
post #7 of 12 Old 05-14-2013, 03:32 AM Thread Starter
GRAND_WJ
It sounds really roaring/growling and shift loads of vibrations... How do you know for sure?
Oh yea should also add (ill add to original post) when in low range I hear click click click click the faster I go the clicker it gets sounds like every rotation it clicks
GRAND_WJ is offline
post #8 of 12 Old 05-14-2013, 03:41 AM
texlurch
Did you grease the u-joints when you installed it?
And again, what is the pinion angle?
texlurch is offline
post #9 of 12 Old 05-14-2013, 03:54 AM Thread Starter
GRAND_WJ
Yep greased it up and still grease it up every 6 months.. Couldn't say what the pinion is now as I've played with it so much basically gone from one end and in increments of 1mm right though to the opposite end..
GRAND_WJ is offline
post #10 of 12 Old 05-14-2013, 03:55 AM Thread Starter
GRAND_WJ
Ill get the old pinion angle tool out next time I get a chance and ill post it up
GRAND_WJ is offline
post #11 of 12 Old 05-14-2013, 04:26 AM
texlurch
Should be pointing straight in line with the driveshaft. Anything else will give you vibes.
Grab the pinion yoke and check for play while you are there.
texlurch is offline
post #12 of 12 Old 05-14-2013, 06:18 AM
MadderThanMax
Wj
http://www.ehow.com/facts_7662444_ca...-cherokee.html
http://www.ehow.com/how_2179550_disa...sfer-case.html
Mines doing all of the above and has had fresh fluid..:-(
