-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   Vibration..really bad (http://www.jeepforum.com/forum/f310/vibration-really-bad-1522645/)
GRAND_WJ 05-13-2013 05:18 AM
Well time to fix the vibration in my wj for good... I have the IRO single double driveshaft in my wj and all other info in sig..
Doesn't matter what adjustment I set the castor to vibration never goes away...been there from day one, its not just a simple hum but it vibrates like crazy especially when on sitting on the highway. But only there when I'm on the gas, if I release it its practically not there, so quite...
Should also add when in low range I hear click click click click the faster I go the clicker it gets. sounds like every rotation it clicks...
Ideas anyone?
Thanks
texlurch 05-13-2013 06:08 AM
Is the pinion pointing at the driveshaft? And the double cardan end is on the T-case, correct?
Forget the caster; only cure for bad vibes is to put the pinion angle right.
Mines about 2 deg off right now and I get an ever so slight very minor hum at 85 or so.
I'll be rotating the C's soon to put it all right.
MuddyWJ 05-13-2013 08:09 AM
How old are the ujoints?
skain8 05-13-2013 10:51 AM
219 Attachment(s)
Are you positive the driveline vibrations are sourced from the front, and not the rear, or a combination of front & rear? At 8" lift, you really need to be thinkin SYE, if you don't have one already.
GRAND_WJ 05-14-2013 03:17 AM
Driveshaft is on correct, this has been an issue from day one... All vibrations are from the front, all disappear when driveshaft is removed... Would I need a double double?
MadderThanMax 05-14-2013 03:24 AM
Suggesting its your TC that's causing it.. does it sound roaring or growly when in gear?
GRAND_WJ 05-14-2013 03:32 AM
It sounds really roaring/growling and shift loads of vibrations... How do you know for sure?
Oh yea should also add (ill add to original post) when in low range I hear click click click click the faster I go the clicker it gets sounds like every rotation it clicks
texlurch 05-14-2013 03:41 AM
Did you grease the u-joints when you installed it?
And again, what is the pinion angle?
GRAND_WJ 05-14-2013 03:54 AM
Yep greased it up and still grease it up every 6 months.. Couldn't say what the pinion is now as I've played with it so much basically gone from one end and in increments of 1mm right though to the opposite end..
GRAND_WJ 05-14-2013 03:55 AM
Ill get the old pinion angle tool out next time I get a chance and ill post it up
texlurch 05-14-2013 04:26 AM
Should be pointing straight in line with the driveshaft. Anything else will give you vibes.
Grab the pinion yoke and check for play while you are there.
MadderThanMax 05-14-2013 06:18 AM
http://www.ehow.com/facts_7662444_ca...-cherokee.html
http://www.ehow.com/how_2179550_disa...sfer-case.html
Mines doing all of the above and has had fresh fluid..:-(
The time now is 09:50 AM.
