vibration. front driveshaft? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > vibration. front driveshaft?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winch sale-- Best deal you will find. and FREE SHIPPIFree Air Compressor with Purchase of ARB air locker
Unread 04-20-2010, 01:44 PM   #1
rlewi09
i just replaced my front driveshaft about 3 weeks ago and ever since then i have had a pretty bad vibration above 60 mph. just to be clear, it is ONLY above 60 mph and if im over it and drop back down to 55 it goes away. i feel it in the seat and in the steering wheel. i put 4 wheel drive in neutral and the transmission and tried to turn the front driveshaft and it was locked. it also has some play in it when i shake it. also my 4 wheel drive part time light is on and a mechanic told me i was driving around in 4 part time but the stick is engaged in 2 wheel drive. any ideas on what this could be?
rlewi09 is offline   Reply With Quote
Unread 04-20-2010, 01:49 PM   #2
swirls
What type of drive shaft? Tom Wood's Custom Drive Shafts - Tom Woods Custom Drive Shafts Custom Driveshafts Specialist
-0|||||0-
swirls is offline   Reply With Quote
Unread 04-20-2010, 09:05 PM   #3
rlewi09
i just got a used one so i guess just factory?
Unread 04-20-2010, 09:35 PM   #4
EisBlade
I, Soldier.
EisBlade's Avatar
not sure what the bolt-up pattern on the shaft you just installed, but see if you can unbolt it, rotate it 90 degrees, and bolt it back up. It could just be a matter of harmonics.
If that doesn't work, and intent on keeping that shaft, yank it off and let a local machine/drive shaft shop check its balance. Shouldn't cost more than 15-20 bucks.
JT
LIFTs, TIREs, SPRINGs & GEARs:
WJ Spring Rate Chart. /// .Tire Size vs Lift. /// .Tire Size vs Gear Ratio. /// .WJ Noob Lift Chart
Driveshaft Angles & Pics of Rear Diff Pumpkins:
Correct Pinion Angles. /// .Correct Driveline Geometry 101. /// .Rear Differential Covers; What They Look Like
Death Wobble (DW): IRO 'Death Wobble Checklist'. /// .More DW Notes (from JK forum)
WJ Emergency Brake Reset Procedure: Click For PDF
WJ Headers: Doug Thorley Header pics for 4.0L 99-01 WJ's ($499)
Click here to view my sexy Jeep girl, and then watch her slay you.
Raunchy Racine
DISCLAIMER: Not responsible for men of weak character.
EisBlade is offline   Reply With Quote
