Vibration damper on bottom of trans? - JeepForum.com
post #1 of 13 Old 11-11-2013, 07:11 AM Thread Starter
dirtyjeepman
I have a question and have searched the threads to try to find it but I have not been able to. I have a WJ that I did an engine swap on, the exhaust hanger by the trans has a round bar with a threaded end that is the nut for the exhaust hanger then it comes down and meets another bar that is bolted to the bottom of the bell-housing. The one on the trans goes through a hole on the one that holds the exhaust hanger. I put a bolt on it but there is not enough thread on it to tighten it. Obviously I am missing something but I have not a clue what it is. Who can fill me in on this mystery? Thanks!
dirtyjeepman is offline
post #2 of 13 Old 11-11-2013, 07:36 AM
cykaaro
Ok, I'm confused. Do you have a pic?
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #3 of 13 Old 11-11-2013, 08:04 AM
Cirruslydakota
I think hes talking about the engine/transmission vibration braces on the 4.0/42re that run along the passenger side.
Youre trying to thread the hanger bolt through the casting ear on the transmission and into the brace correct?
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
post #4 of 13 Old 11-11-2013, 12:21 PM Thread Starter
dirtyjeepman
I guess thats what it is, I really dont know and none of the WJ's I look under to see what it is have it.. I am at a loss. I have attached a picture.. Thanks!
post #5 of 13 Old 11-11-2013, 07:20 PM Thread Starter
dirtyjeepman
As you can see from the photo there is slack behind the bracket like a half an inch or so..
post #6 of 13 Old 01-29-2014, 06:45 AM
pdpunome
Did you ever figure this out?
2000 4.0 Selec Trac
pdpunome is offline
post #7 of 13 Old 01-29-2014, 07:33 AM
doityourselfMM
doityourselfMM's Avatar
EDIT - I just looked underneath my '99 4.0. There is another bracket which your vehicle seems to be missing. The thickness of the 'collar' on that bracket is about 1/2", which would solve your mystery.
doityourselfMM is online now
post #8 of 13 Old 01-29-2014, 08:34 AM
ChrisHager
Administrator
ChrisHager's Avatar
Haven't seen that before. What engine/trans is this?
Though it's not possible unless you moved it, it sure looks like the end of the sway bar, doesn't it?
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is online now
post #9 of 13 Old 01-29-2014, 08:58 AM
Cirruslydakota
Youre missing the brace that bolts to the side of the engine that meets the other two brackets. I'll post a pic from the FSM.
Bear - 99 WJ Laredo
post #10 of 13 Old 01-29-2014, 09:06 AM
doityourselfMM
It's about 10 degrees outside, and my WJ has no lift. This is the best I can get. Excuse focus and lighting, but I think you'll see what I'm referring to.
post #11 of 13 Old 01-29-2014, 09:13 AM
ChrisHager
Administrator
ChrisHager's Avatar
That's actually a great picture, doityourselfMM. I'm curious and need to look at mine the next chance I get - I don't recall seeing that!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #12 of 13 Old 01-29-2014, 09:16 AM
Cirruslydakota
^^ Yeah, im not about to go outside before I have to go to work, lol.
Bear - 99 WJ Laredo
post #13 of 13 Old 01-29-2014, 12:16 PM
doityourselfMM
By the time I came back in the house, I was 'tinkling like ice cubes', if you catch my drift.
