Quantcast Vari-Lok or Trak-Lok---Do I Have it? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Vari-Lok or Trak-Lok---Do I Have it?
RUBICON EXPRESS Lift Kits and Accessories Available at BasSpartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-Road
Old 07-20-2007, 07:41 AM   #1
Greydane
Hello:
I have a 1999 Grand Jeep Cherokee Vin 1J4GW58S4XC651974. The Front Axle is a Dana 30 (186Fb1) and the Rear Axle is a Dana 35C (198RBI). The Transfer case is the Select Trac NV242.
How can I tell if I have the Vari-Lok or Trak-Lok option? Note that I may not have the Lok options at all. I want to change the fluids in the axles with a 75-140 oil; however, if I have the Lok options I must add a Limited slip additive. If I don't have those options then I only add the Oil. Thanks in advance for the help.
Bruce
Greydane is offline   Reply With Quote
Old 07-20-2007, 07:43 AM   #2
hinchcliffe
Do a search to find out how to get your build sheet e-mailed from DC. that'll tell you.
'06 XK Inferno Red Crystal Pearl/Gray Leather
hinchcliffe is offline   Reply With Quote
Old 07-20-2007, 08:49 AM   #3
rm2001wj
Confirmed Street Jeeper
rm2001wj's Avatar
For sure you don't have either option in the front differential. Trac-Loc was not available for the front and for Vari-Loc to be there, you had to have Quadra-Drive with the NV247 TC.
For Vari-Loc rear, the 226RBA (Dana 44a) differential was needed. At best you would have Trac-Loc in the rear. I've read that if you jack up the rear axle so that both wheels are off the ground and rotate one wheel, then if the other rotates in the same direction, you have Trac-Loc.
Getting the build sheet would let you know for sure. Or, you could get one off the gear lubes that have the friction modifier in it already, Redline for example. Friction modifier in the lube used for an open differential will have no adverse effects.
2001 WJ Limited with Quadra-Drive, Kenne Bell Supercharger, 3-inch Kolak exhaust, Stillen rotors (F/R) and MM pads, Addco sway bars (F/R).
rm2001wj is offline   Reply With Quote
Old 07-26-2007, 05:45 PM   #4
ghcoe
1994 ZJ
Should have a tag on the diff cover that says to add a additive to the lube if it has a locker. It will be held on by on of the cover bolts, simular to the gear ratio tag.
ghcoe.
George.
1994 ZJ, 318 (5.2), (Was NP249) Now NP 242 external slip, 2" BB lift, 235/75/15 Bridgestone TA ko's.
ghcoe is offline   Reply With Quote
Old 07-26-2007, 08:21 PM   #5
zaq123
1941 MK Compass
fill out this form and put " build sheet request" in the description
Jeep will send all info about your grand, the way it came from the factory.
http://www.jeep.com/wccsapp/universal/J/index.jsp?appStr=wccs&titleStr=Contact+Jeep&family Str=brand&franchise=J&actionURL=%2Fwccs%2Fbrand_fo rms%2Fus%2Fwebform.jsp&promotion=null&category=U
Welcome to JF
zaq123 is offline   Reply With Quote
Old 07-26-2007, 10:03 PM   #6
Greydane
Thanks Everone
Thanks for the help. Got the build sheet. I do not have vari or track lock.
Glock Forum
