Valve covers - JeepForum.com
post #1 of 7 Old 03-13-2014, 06:16 PM Thread Starter
MJ1982
Valve covers
I replaced my driver side valve cover gasket, purchased from the dealer, a few months back and no leaks, but a few days ago it started leaking again. I have a 4.7l with 167k on the odo. The heads have never been overheated. Thanks in advance!
MJ1982 is offline
post #2 of 7 Old 03-13-2014, 06:26 PM
pinky2252s
Well, okay. Did you have a question?
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #3 of 7 Old 03-13-2014, 06:58 PM
rdkendrick
2003 WJ
Did you save the receipt?
Sent from my iPad using electrons
rdkendrick is offline
post #4 of 7 Old 03-13-2014, 09:29 PM
corpulent
You might just check that the bolts are still torqued, and if it still leaks take off the cover and use a straightedge to check that it is absolutely flat. Mine leaked from a small bend near a bolt-hole until I coaxed it back into shape.
corpulent is offline
post #5 of 7 Old 03-14-2014, 12:45 PM Thread Starter
MJ1982
I will go ahead a check it with a straight edge. I will see if that helps. Thanks. Also, whats a good gasket. It seems that the deep freeze we had here in DC did something to the gasket the dealer sold me.
MJ1982 is offline
post #6 of 7 Old 03-14-2014, 01:28 PM
corpulent
I used a fel-pro on mine. Seems well-made; comes with new grommets.
Supposed to be re-usable too.
post #7 of 7 Old 03-14-2014, 01:35 PM
pinky2252s
Fel-pro is very good gasket. Make sure to keep it in your house before putting it on, so it can stretch and move a little bit.
Is it broken?
