Vacuum Question - JeepForum.com
post #1 of 5 Old 12-18-2013, 09:27 AM Thread Starter
Son-of-Beast
Vacuum Question
Curious if vacuum plus manifold pressure reading should be roughly equal to barometric pressure? Running Torque and watching realtime data I typically see a vac reading of 11-22 or so depending of course on load, with a manifold reading of 3-9 on average. I would expect that the two together should be roughly equal to barometric depending on load, and wonder if I may have a vac leak driving my gas mileage down.
Any thoughts or info are appreciated.
'Son-of-Beast' - '02 WJ Limited, 4.7, 545RFE 5-spd Auto, Quadra-Drive, KOR 2.5" BB, Rancho RS5000's, Firestone Destination AT 265/70R17's, Flowmaster DeltaFlow 40, KMA/TAG armor, JK Fuel Door, Spyder CCFL Halo Projectors, LED Taillights, LED Interior Lights - Build Thread:
Son-of-Beast is offline
post #2 of 5 Old 12-18-2013, 04:47 PM
rm2001wj
rm2001wj's Avatar
The answer to your question is Yes. Manifold absolute pressure is pressure above zero, and manifold vacuum is pressure below atmospheric. Add the two (expressed in the same units) and you get atmospheric pressure at your location.
rm2001wj is offline
post #3 of 5 Old 12-18-2013, 05:01 PM
jeepingcolorado
Is there a beginners guide to fixing a vacuum leak? I tried searching and didnt find anything on how exactly to proceed the cel's im getting are po442 and po445
jeepingcolorado is offline
post #4 of 5 Old 12-18-2013, 06:18 PM Thread Starter
Son-of-Beast
Those are evap system codes, hoses run from pcv and resonator I believe in the engine compartment, along the left side rail of the unibody to the evap canister in the left rear wheel well. Look for cracks or splitting or just replace them.
post #5 of 5 Old 12-18-2013, 06:43 PM Thread Starter
Son-of-Beast
Thanks rm, that's what I thought but wanted a verification.
