vacuum leak the high RPM's? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > vacuum leak the high RPM's?
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! USA Standard Chromoly Front Axle Shaft Kits with Dana 30 4The Jeep Forum Discount is ON!
Unread 08-14-2015, 10:45 AM   #1
Jrboarder27
I have noticed a hissing sound when my windows are down and at high RPMs. I was wondering if I should be looking for a vacuum leak and where the leak might be.
Jrboarder27 is offline   Reply With Quote Quick reply to this message
Unread 09-02-2015, 12:00 PM   #2
Jrboarder27
Bump
Unread 09-02-2015, 12:02 PM   #3
Jrboarder27
So I'm going to add to this.
I have also recently noticed a hissing sound behind my dash at idle and goes away when I give it gas, and brake pedal does not affect sound.
Unread 09-03-2015, 02:58 AM   #4
james_2k
2009 WK
is it a constant hissing? or an engine noise modulated kind of sound.
james_2k is offline   Reply With Quote Quick reply to this message
Unread 09-03-2015, 06:49 AM   #5
MadderThanMax
Yeah a bit more detail please: Engine type etc would help...
Have you tried locating it yourself? where does it come from - and don't say "In the window when I open it.." Is it front, left, Front right, at the bulkhead or what, even underneath the car can have a hiss.. so a little more detail please, otherwise throw the viper out on the passenger side (also known as the missus!)
MadderThanMax is offline   Reply With Quote Quick reply to this message
Unread 09-03-2015, 06:51 AM   #6
MadderThanMax
At the moment I'm sticking my neck out here and saying that its a pin hole in the pipe or muffler...
Unread Yesterday, 11:55 AM   #7
MadderThanMax
Hello?? Anynone there??
Unread Yesterday, 11:59 AM   #8
AWDigging
I would look in the exhaust.
Vacuum leaks do not usually materialize only at a certain load.
Exhaust leaks can tho and often do
AWDigging is offline   Reply With Quote Quick reply to this message
