Upper & Lower spring isolators - JeepForum.com
post #1 of 6 Old 04-12-2011, 12:14 PM Thread Starter
jemrey81
where's the best place to get these? Are there differences in quality if I go aftermarket vs. oem? Reading around it looks like the lowers are more important than the upper (by more important I mean they show more wear)..... I don't want to buy all 4 yet, but I would like to replace a couple when I have it apart.
thanks for any info you have
jemrey81 is offline
post #2 of 6 Old 04-12-2011, 02:26 PM
KDog223
Check Iron Rock Offroad. I've lost a front spring when my sway bar was disco'd and I only had the lower retainers. I'd recommend both the upper and lower if you are doing any kind of wheeling.
Edit: Nevermind, I thought you meant spring retainers, not isolators.
KDog223 is offline
post #3 of 6 Old 04-12-2011, 02:27 PM
Apollo21
Junkyard
Midshipmen Patrick 1/C USMMA DD: 2004 Golf GLS TDI 43mpg and 2002 Overland: Zone 4in, 32in Treadwright MTRs, IRO upper CAs, lift gate light mod, Alpine/Polk speakers, and power inverter with USB in dash mod, CB, custom rear swing out tire carrier Build thread
SOLD
Apollo21 is offline
post #4 of 6 Old 04-12-2011, 02:41 PM
narnwv
narnwv's Avatar
Originally Posted by Apollo21
Junkyard
You dont want used ones.
Get them from Rockauto.
Sent from my HERO using JeepForum app.
~Aaron
narnwv is offline
post #5 of 6 Old 04-12-2011, 03:24 PM
dustinova
I got the full set from Rock Auto as well. The Raybestos brand. They run around $100 shipped. Mine were pretty easy to replace too because I didn't have to fight any rust. I replaced mine when I put the lift on to give the new springs as solid a resting place as possible.
2001 WJ Laredo - 4.0 - Zone 4" Lift, IRO Adjustable Front Upper Control Arms, Spidertrax Wheel Spacers, Hella 700ff's
dustinova is offline
post #6 of 6 Old 04-12-2011, 03:34 PM
LeroyJMC
1994 ZJ
Yup. Rock Auto - Raybestos.
2009 Red Rock JK Unlimited Rubi
2006 Scion xA
1999 WJ Limited Quadradrive V8
1997 Chevrolet Z71
1994 ZJ Laredo 4.0 - Sold
Thanks for the IR Remote Smokinbk.
LeroyJMC is offline
Front Suspension Spring Isolators replace torx WJ Grand Cherokee Forum 7 11-16-2010 11:51 AM
TJ lower and upper control arms? sparky2star WJ Grand Cherokee Forum 3 10-16-2010 11:57 PM
WJ 4.7L V8 upper and lower radiator hoses Wheelin98TJ WJ Grand Cherokee Forum 1 06-22-2010 09:15 AM
WJ 4" lift - Adj Control Arms - Upper Lower swirls WJ Grand Cherokee Forum 6 06-12-2010 11:33 AM
03wj ball joint questions adjustable/deg/upper or lower ronsaun WJ Grand Cherokee Forum 0 05-18-2010 01:09 PM
