Upgrading to heated seats on an '04 Laredo - JeepForum.com
post #1 of 10 Old 10-06-2013, 09:30 AM Thread Starter
JeepsOLot
Had the seats and switches installed for some time now. WJ Jeeps and others that have down this upgrade say that the plugs for the switches are there, I just can't find them!! I've taken the whole center dash out; radio, radio bezel, climate controls, and ashtray/switch bezel. There are no switch plugs for the heated seats that I can see. Does anyone with an '04 Laredo that has done this upgrade know if the switch plugs were there, or, did you have to wire them up? The reason I'm asking is, I had a hell of a time finding the plugs for the auto dimming rear view mirror and the auto headlight sensor in the dash. I wanted to know every place these plugs could be before I give up and wire them in myself. Thanks!
Jerry
86 MJ LB Custom, 88 MJ SB Eliminator, 92 CJ9, 93 XJ Country, and 04 WJ Laredo/Limited
JeepsOLot is offline
post #2 of 10 Old 10-06-2013, 09:34 AM
vanillathrilla
I'm interested to know too. We have a 2004 Laredo as well and I've found some decent seats at the salvage yard (which I didn't buy), and heated seat switches are pretty common out there. If there's a harness for them, it seems like it'd be an easy mod. I'll have to crack open the dash and see if I can find a harness myself
'99 TJ Sport | Rampage Frameless | 33x12.50x15 Goodyear MTR/K's | Poweraid TBS | Flowmaster 40 series | Herculined | 15% tint | LED interior lighting | AtoZ front/rear bumper | AtoZ tube rocker guards | Kenwood Excelon KDC-X993BT | Kicker 6.5's in soundbar | Alpine Type-R 4x6's in dash.
vanillathrilla is offline
post #3 of 10 Old 10-06-2013, 09:43 AM Thread Starter
JeepsOLot
Let me know what you find, I just checked this morning, and still couldn't find anything! Like I said, I had to ask around and really look around to find the plugs for the auto headlight sensor in the dash and the plug for the auto dimming rear view mirror above the headliner, above the EVIC. Thanks!!
Jerry
post #4 of 10 Old 10-06-2013, 10:46 AM
99WJ539918
When I did the upgrade in my '99 I didn't have to look hard at all for the wiring for the switches. It might not be there.
Build Thread
99WJ539918 is offline
post #5 of 10 Old 10-06-2013, 10:51 AM Thread Starter
JeepsOLot
Thanks, that's what I was afraid of, the '04 Laredo's may not be wired. This opens up another question, how far back does this go, just '04's or earlier?
Jerry
post #6 of 10 Old 10-06-2013, 02:52 PM
coloradowjowner
If you can't find the switch bezel behind the dash. The other option may be installing a three way switch mounted to seat somewhere. I did this to a 97' f150 when I upgraded the seats. Worked well.
coloradowjowner is offline
post #7 of 10 Old 10-06-2013, 03:11 PM Thread Starter
JeepsOLot
Yeah, true, I could go that route, but, I've got the switches and the bezel, so, I can wire it up, just trying to cut down as much as I can, LOL!
Jerry
post #8 of 10 Old 10-06-2013, 03:14 PM
coloradowjowner
Originally Posted by JeepsOLot
Yeah, true, I could go that route, but, I've got the switches and the bezel, so, I can wire it up, just trying to cut down as much as I can, LOL! Jerry
Yeah doing it my way would be worse case
post #9 of 10 Old 10-06-2013, 07:59 PM
snobrdrkid07
snobrdrkid07's Avatar
I'm in the same boat. I have a 2004 Laredo and got a full set of premium leather seats from a 03 Limited. I do not have the harnesses behind the dash either.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #10 of 10 Old 10-06-2013, 08:32 PM Thread Starter
JeepsOLot
Ok, looks like '03-'04 Laredo's don't have the heated seat switch plugs. I'm wondering if, with the '02 refresh, the plugs were removed from the main Laredo harness. Thanks for the info. Anyone with an '02 Laredo have the plugs or not?
Jerry
