Upgrade lift 4" to 6"ish - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Upgrade lift 4" to 6"ish
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFord Explorer 8.8 4340 Chromoly Axle Shaft Kit C Clip Elim07-15 jeep JK Spare Tire Carrier Delete Plate
Unread 03-25-2015, 11:51 PM   #1
AOTiger62
Hey guy I need some help on my lift. I currently have a IRO 4" adjustable long arm kit and I really want some extra hight. I was wondering if I switch the coils out for some new one. Would I run into issues? OR should I get some BB to put on top of my current lift? I'm wanting to run some 33's 35's. Thanks for the help!
AOTiger62 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 07:27 AM   #2
ChrisHager
ChrisHager's Avatar
If you already have a long arm kit, you can bump up to either 6" coils or add a 2" BB to your 4" coils. Both result in the same overall lift height. Personally, I'd opt for new coils.
Keep in mind, bumping up 2 inches may require some lift adjustments. 35s will also increase the need for a regear.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by alfaitalia View Post
"Wind them in until you strip the thread....then back a quarter turn!"
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 07:52 AM   #3
MadCharger
May need to swap shocks also....
'04 Grand Cherokee Overland || 4.7 HO || 6" Clayton || 35" Mud Country || 242HD swap
MadCharger is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 09:35 AM   #4
SupraEv
PM me if you wanna sell the 4"
SupraEv is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 10:07 AM   #5
AOTiger62
Ok cool. if go with the 6" will I need a rear long arm kit? Also do 33's require regearing too? Also coils who makes the best coils that won't droop after while.
Unread 03-26-2015, 08:06 PM   #6
Kolak
Vendor
Kolak's Avatar
The ride at 6" with short arms in the rear is a bit choppy but lots of people do it and daily drive their WJs without much complaint.
What's the reason you're wanting to lift higher? Are you wanting still taller tires? Keep in mind that one thing that does get impacted is onroad handling due to the higher center of gravity.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
kolak@aol.com or kolak@kolakperformance.com
Kolak is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 11:08 PM   #7
AOTiger62
Thanks for posting kolak I don't know if you remember me I bought my lift from you about a year ago.
The main reason I'm wanting a high lift than 4" is after offroading for a good while seem I need some more ground clearance. I got a buddy that has a XJ who's running 35's on 5.5 lift. I'm thinking 33's tires would be a good spot for me but I'm not wanting to chop up my fender up. At 32's I'm rubbing a bit so I'm thinking if I go with 33s I'm gonna need to chop the hell of it.
Also about the rear arms if I do go with the taller lift which arms do you recommend I heard will IRO kit once it's installed you can't really change the height of it.
Thanks for any help
Unread 03-27-2015, 01:02 AM   #8
Kolak
Vendor
Kolak's Avatar
How about just some fender flares?
Sorry to try to talk you out of lifting it higher but it's going to be costly since you've already got the 4" lift and will need longer shocks, front & rear swaybar links and of course the new springs.
Unread 03-27-2015, 07:08 AM   #9
ChrisHager
ChrisHager's Avatar
This is a great idea. You'll keep your current on and off road mannerisms yet be able to run a larger tire.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 03-27-2015, 10:52 AM   #10
AOTiger62
Ok I might just do that because I love how it drives right now on and off road. After looking around for some fender flares cost around $500 For bushwackeris there another brand I should look for?
Unread 03-27-2015, 11:25 AM   #11
texlurch
There is a Polish company making some similar to the Icelands; give a little more clearance than the BW.
Just another old fart in a Jeep... watchout younguns!!!
RC LA, IRO 6 in springs, OTK, Bilsteins, Aussie, Eaton, RCV's, 242-SYE, hidden winch, JCR Stage 3, skidded and trussed & sleeved
Colorado Jeep Club Member #383
texlurch is offline   Reply With Quote Quick reply to this message
Unread 03-27-2015, 11:31 AM   #12
AOTiger62
Do you have a link for them? Thanks
Unread 03-27-2015, 11:57 AM   #13
texlurch
http://www.ebay.com/itm/JEEP-GRAND-C...b93f83&vxp=mtr
Unread 03-27-2015, 02:26 PM   #14
AOTiger62
Looked in to the Flares and found a thread about them. They look kinda sketchy they don't bolt on its adhesive glue he gives you. I'm not sure if it's going to last.
Unread 03-28-2015, 12:44 AM   #15
AOTiger62
Do you sell any fender flares?
