Unsolvable problem with the WJ. HELP - Page 2 - JeepForum.com
post #16 of 29 Old 10-21-2013, 07:11 PM Thread Starter
DakMan96
I'm about ready to throw my jeep off a cliff. Is there anything else I can check? P1595 is killing me
DakMan96 is offline
post #17 of 29 Old 10-22-2013, 06:56 AM
stonefarg-NM
I had some similar symptoms with my 4.7 - turned out to be low fuel pressure. Replaced filter/regulator problems solved. It was throwing a different code (P0171) that made me think twice, but in the end the low fuel pressure caused the odd code. A pressure check at the rail will tell you.
Just a thought #goodluck
via mobile
stonefarg-NM is offline
post #18 of 29 Old 10-22-2013, 12:45 PM
1hotrod
Since you stated that you smell gas, it's posssible you have a weak ignition. Have you pulled the plugs to check for fouling/ carbon deposits? Or possibly a fuel delivery problem like large variations in fuel presssure. Check fuel rail pressure with a gauge, not sure what it is supposed to be, but I would guess between 50 and 60 psi. I sure someone here can help you with that number. Anyone??
1hotrod is offline
post #19 of 29 Old 10-22-2013, 12:50 PM Thread Starter
DakMan96
Great idea! I'm definitely doing this, so I'll reiterate what you just said. Anyone know what PSI I'm looking for?
DakMan96 is offline
post #20 of 29 Old 10-22-2013, 03:03 PM
stonefarg-NM
Its 49psi for the 4.7...
via mobile
post #21 of 29 Old 10-22-2013, 05:59 PM Thread Starter
DakMan96
via mobile
I have the 4.0. You know that one?
DakMan96 is offline
post #22 of 29 Old 10-22-2013, 06:24 PM
stonefarg-NM
According to the FSM, either motor should be 49.2 psi +/- 5 psi on the rail test port at idle. Pressures outside the limits suggest specific problems.
via mobile
post #23 of 29 Old 10-22-2013, 06:39 PM
stonefarg-NM
Below 44.2 is bad filter/regulator, bad pump, or other kinked/obstructed fuel line. Above 54.2 is bad filter/regulator. My pressure was 35 so I decided to try filter/regulator & got lucky first try.
Do you have a FSM? if not, one can be downloaded @ jeepslimited.com I think there's a registration and small server fee. Good source of info.
Good luck
via mobile
post #24 of 29 Old 10-23-2013, 12:08 AM
rep-tile
Cash 4 Clunkers Survivor
rep-tile's Avatar
Forget about P1595, it's a fluke. Now how corroded are your battery cables?
rep-tile is offline
post #25 of 29 Old 10-23-2013, 08:46 AM Thread Starter
DakMan96
They were cleaned a couple months ago so not too terribly bad. Could they cause the code to throw? But how would this explain the stalling and lack of power?
DakMan96 is offline
post #26 of 29 Old 10-23-2013, 08:04 PM
rep-tile
rep-tile's Avatar
The ECU controls anything from ignition timing to air/fuel ratio to ability to maintain idle, and it particularly doesn't like low voltage, so there you go. That can easily explain stalling, lack of power, and bogus codes; and that would be the very first thing I'd check.
These are battery cable connectors I just pulled out of my WJ that didn't look "terribly bad" on the surface. Turns out they were 95% corroded...
rep-tile is offline
post #27 of 29 Old 10-23-2013, 08:14 PM Thread Starter
DakMan96
Might be the best advice yet, now I need to get my lazy self to do it. I have the flu right now but I still might try tomorrow to at least get a good look at it. Thanks a ton man
DakMan96 is offline
post #28 of 29 Old 10-23-2013, 08:59 PM
new2site
Mine were just like that...totally corroded on the inside... just suggested this could be problem to someone else here and it WAS (different issue though).
Take a wire brush to the corroded wires / baking soda-water mix / contact cleaner too..if you have some.
As you know these WJ's have dual cables for each terminal so you either mickey-mouse your cables to fit some "standard terminals" or buy whole new cable a$$embly ..or spend some time doing it this way(I did this with mine):
http://www.jeepforum.com/forum/f310/...ables-1144633/
http://www.jeepforum.com/forum/f310/...index1614.html
And for your flu: http://www.walmart.com/ip/Equate-Flu...ingMethod=p13n
This is the same as good ole Theraflu ...which was discontinued...works great (make sure to get "daytime" formula )
new2site is offline
post #29 of 29 Old 10-28-2013, 05:35 PM
dinorigginwj
My 4.7 has almost the exact same drive ability concern as the original poster. Very interested to see how this turns out. I have suspected fuel pressure issues as well as battery terminal corrosion. If I fix mine I'll post results.
dinorigginwj is offline
