Unexpected MPG for JGC WJ 01 4.7 - Page 2 - JeepForum.com
post #16 of 42 Old 05-02-2013, 07:54 PM
doc8669
Originally Posted by miami5th
I should also mention that I am using Bosch o2 sensors.
What was your mpg before installing the Bosch o2 sensor?
doc8669 is offline
post #17 of 42 Old 05-02-2013, 09:19 PM
86cj74.2L
86cj74.2L's Avatar
Originally Posted by ezflip
Dump the crown TPS and get one from MOPAR. These things are very very picky about their sensors. Anything electronic, use nothing but Mopar.
Plus 100.
And when did you put the Bosch sensors in?
Mopar and Bosch do not get along very well. And using them with no issues associated with using then seems to be the exception.
Mopar or NTK brand sensors are what get along with the PCM.
86cj74.2L is offline
post #18 of 42 Old 05-02-2013, 10:48 PM
miami5th
my mpg before the bosch sensor was a little lower, probably 17/18 city 21/22 highway
miami5th is offline
post #19 of 42 Old 05-02-2013, 11:16 PM
pinky2252s
Originally Posted by 86cj74.2L View Post
Plus 100.
Pretty sure Bosch makes the stock O2 sensors for Mopar. Also Bosch kind of invented the o2 sensor so I'd be surprised if it caused any negative affects.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #20 of 42 Old 05-03-2013, 03:10 AM
86cj74.2L
86cj74.2L's Avatar
And I know a lot of people that installed them thinking what your thinking and had nothing but problems.
post #21 of 42 Old 05-03-2013, 04:33 AM Thread Starter
veiri86
2003 WJ
A new update.
I unplugged the battery again for almost two hours this time, then plugged it again, and did my normal trips, now am getting around 16 mpg highway.
But from now on no any electronic for the jeep other than Mopar.
Talking about the oxygen sensors, am supposed to have one before the cat and one after, when i went under the car, i found one place before the cat but there was no sensor, just a plug, please check the photo below, can it be like this?!!!!
R.I.P ratmonkey
Build thread:
01' 4.7 Limited WJ 5" lifted, Rubicon Express 4.5" coil springs with IRO critical path setup and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), JKS HD tie rod (MOOG problem solver Ends), JKS HD drag link (Moog Probel solver Ends), 4.56 Yukon ring and pinion, Moog HD SSD107 Steering Stabilizer, IRO Front drive shaft conversion, Stillen slotted rotors all around with Stillen brake pads, IRO adjustable A-Arm, 3" all the way Kolak Exhaust with High flow Magnaflow Cat. Converter and Flowmaster Super 50 Muffler, 285/70R17 AT Kumho (33") on 17" BlackWheel rims 909B, K&N Cold air intake, Four nozzles Bosch injectors, and Flashpaq 3780.
03' 4.7 H.O WJ 3" lifted, OME HD with 0.5" Coil spacers and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), Moog Problem solver TRE's, IRO Front drive shaft conversion, IRO adjustable A-Arm, High flow magnaflow mini cats, high flow magnaflow cat, Flowmaster Super 44 muffler, 265/65R17 AT Yokohama on 17" Rays rims, and Flashpaq 3780
veiri86 is offline
post #22 of 42 Old 05-03-2013, 05:37 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Denso and NTK were the factory O2s. And, if you dont buy them directly from Mopar (even if they have the exact same part numbers) they are not made to Mopar spec. Ask me how I know. I dropped almost $1000 on O2 sensors a couple of months ago.
~James
ezflip is offline
post #23 of 42 Old 05-03-2013, 05:54 AM
Double E
Double E's Avatar
Originally Posted by veiri86 View Post
A new update.
Attachment 620590
You may have that configuration because you are not subject to US emissions standards?
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #24 of 42 Old 05-03-2013, 10:54 AM
WJChris
WJChris's Avatar
Attachment 620590
Yes, That extra sensor is for US emissions standards. You should be fine!
WJChris is online now
post #25 of 42 Old 05-03-2013, 11:34 AM Thread Starter
veiri86
2003 WJ
Wj
So is it possible my JGC runs without O2 sensors?
veiri86 is offline
post #26 of 42 Old 05-03-2013, 06:28 PM
doc8669
So here's a question, what should the city/hwy mileage be on a 4.7L H.O V8 because mine evics reading between 12 hwy and 9/10 city(02 wj overland)
doc8669 is offline
post #27 of 42 Old 05-03-2013, 06:34 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Thats about where I am but Im also lifted 4" on 32" KMs and around 500# in extras.
~James
ezflip is offline
post #28 of 42 Old 05-03-2013, 06:39 PM
doc8669
I researched it and online states 17 hwy and 12 city for the H.O model. I'm no where near that
doc8669 is offline
post #29 of 42 Old 05-04-2013, 06:02 AM
lazyWJ
2006 XK Commander
Ignore your evic. It is always wrong and never consistently so (could be over, could be under although they are generally optimistic). Calculate your mileage tank over tank. You aren't far off from what you should be getting, I average about 13mpg in mixed driving in my 02 overland with 2" lift and 31's. I'm sure if I could find a straight, flat piece of highway I would be amazed at what it could do, but that's just a dream where I live.
Do an odometer check! Half the people posting their fuel numbers don't even know what one is, and it's vital to knowing your true consumption. Try not to pay too much attention to the people who are averaging 25mpg on their lifted WJ, they are on another planet where all the roads are downhill. EPA ratings of that era were notoriously generous too.
2004 Imola BMW ZHP
2006 Commander Limited Hemi QD2
"Bought, Not Built"
lazyWJ is offline
post #30 of 42 Old 05-04-2013, 02:18 PM
doc8669
I was thinking of installing and CAI to get better numbers but I'm trying to decide if its worth it or not. We have some pretty cold winters up here and it would hinder the fuel consumption with the colder temperatures. I would probably have to put the stock one back and I don't want to do that
doc8669 is offline
