Uneven rolling in corners - JeepForum.com
post #1 of 6 Old 01-16-2014, 06:50 AM Thread Starter
Matrixxxx
2005 WK
Wj Uneven rolling in corners
hi All,
if im driving along and swerve from one side of the road to the other (road clear)
when i turn to the right it feels ok but when i turn to the right it seems to lean a lot more, i assume it could be the rear shock on the rhs?
it had been stood for a while by the previous owner..
Matrixxxx is offline
post #2 of 6 Old 01-16-2014, 06:53 AM
sfjacks1
I would say you have a broken/ worn out sway bar link...
sfjacks1 is offline
post #3 of 6 Old 01-16-2014, 07:20 AM Thread Starter
Matrixxxx
2005 WK
any simple tests to do other than look at it as it will be the weekend before i get to look at it properly.
it does seem to handle differently depending which corner your going round, i thought it was the Tyre pressures at first but they are fine now i have had the rim leak repaired.
post #4 of 6 Old 01-16-2014, 08:10 AM
pinky2252s
Its something to do with the rear sway bar most likely. Check for any broken bolts on the sway bars axle mount, and the sway bar end links. Make sure your spring isn't broken as well. Also makes sure that none of your shocks are leaking, or have blown a seal.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #5 of 6 Old 01-20-2014, 06:44 AM Thread Starter
Matrixxxx
2005 WK
UPDATE:
all i could find was one of the top arm bushes had some play in it but only a few mm's, spring looks ok , shocks not leaking but do look quire corroded on the exposed parts.
post #6 of 6 Old 08-18-2014, 11:46 AM Thread Starter
Matrixxxx
2005 WK
Update: it turned out to be the drivers side shock absorber -week, replaced all OK.
