Under $100 MODS/UPGRADES - Page 4 - JeepForum.com
post #46 of 83 Old 05-04-2013, 10:10 AM
ZB_WJ
Originally Posted by mycreativename
Is there any noticeable purpose or is it just for peace of mind?
I ask because soon I'm going to be buying a good deal of thick wiring for both an inverter and winch, so if I'm doing it in one place, I might as well do it all, just curious if it makes a difference.
It helps charge the battery faster because you are basically doubling the current. If you start having problems with your lights dimming or battery performance, this is a nice cheap
upgrade the the charging system. I'm pretty sure you need an inline fuse on the positive wire.
Best bet is to get a HO alternator, but those arnt cheap IMO I wouldn't worry about it unless you have problems with lights dimming or. Outage problems
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #47 of 83 Old 05-04-2013, 01:08 PM
alfaitalia
Not doubling the current....won't affect the current at all.....but will greatly reduce the resistance in the wire so less of that current is lost as heat. Imo the standard wires are more than up to the job so you prob won't notice any difference unless you have really heavy current loads like powerful lights or sound system.
Sent from my HTC Wildfire using JeepForum
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #48 of 83 Old 05-04-2013, 02:59 PM
ZB_WJ
Exactly. Less resistance = more current
ZB_WJ is offline
post #49 of 83 Old 05-04-2013, 04:32 PM
alfaitalia
Only if you have a demand for more power than the current wire can supply...if you don't, and most won't, then bigger wires will not increase current.
post #50 of 83 Old 05-08-2013, 05:06 PM Thread Starter
99WJLimited
Did some more painting today for $4. Grill insert and emblems!
Sent from my mind to your screen
99 Grand Cherokee Limited 4.7 45RFE Quadra-Trac II Dana 30 Dana 35 Firestone Destination A/T 245/70R/16
“If I had no sense of humor, I would long ago have committed suicide.” ― Mahatma Gandhi
99WJLimited is offline
post #51 of 83 Old 05-08-2013, 05:28 PM
aralph30
2003 WJ
Originally Posted by 99WJLimited
Did some more painting today for $4. Grill as emblems!
What did u use ?
I LOVE MY JEEP MORE THAN MY GIRLFRIEND :p
aralph30 is offline
post #52 of 83 Old 05-08-2013, 05:30 PM Thread Starter
99WJLimited
Originally Posted by aralph30
What did u use ?
This lol
post #53 of 83 Old 05-08-2013, 05:32 PM
A_Cadilli
I noticed gcjeeping mentioned this is a repeate thread. I'd like to keep one going and maybe in courage people to include pics with their mods . Maybe someone can hit up an admin about a sticky? Cool stuff here!
99 WJ limited 2wd 4.0 STOCK
A_Cadilli is offline
post #54 of 83 Old 05-08-2013, 05:35 PM Thread Starter
99WJLimited
That a great idea. I will see what I can do!
post #55 of 83 Old 05-08-2013, 05:35 PM
aralph30
2003 WJ
This lol
What if u mess up does it come off
aralph30 is offline
post #56 of 83 Old 05-08-2013, 05:36 PM Thread Starter
99WJLimited
Um not that I'm aware of lol. I took the insert out and sprayed it then put it back in. Only took removing 6 screws.
post #57 of 83 Old 05-08-2013, 05:38 PM
lvngtheJEEPlife
Use plastidip if you want it to be removable. peels off like plastic if you mess up or want it off. Sold in spray cans
2001 WJ Limited 4.7 Powertech, Quadradrive, 2" BDS lift.
"If you can't get there in a Jeep, You should reconsider going there."
lvngtheJEEPlife is offline
post #58 of 83 Old 05-08-2013, 05:39 PM Thread Starter
99WJLimited
If you use acetone you can take the paint off only if you do it within a few hours. It will probably etch the plastic though. Once it has set for a day or two it's done lol
post #59 of 83 Old 05-08-2013, 05:40 PM Thread Starter
99WJLimited
I used 2.5 cans of plastidip black spray paint when I blacked out my rims. Stuff is amazing!
post #60 of 83 Old 05-08-2013, 05:46 PM
A_Cadilli
I want to do this as well. Did u just tape the tire off and get at them from the inside and out? How long you been running them with the spray?
