Ultra Gauge - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Ultra Gauge
Free shipping on Rugged Ridge XHD bumpersBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 08-23-2013, 01:11 PM   #1
bcvetter
Ultra Gauge
Considering an Ultra Gauge for my WJ. Was thinking about mounting it in the cubby below the AC controls. Question is has anyone done this? and if so any pics?
Also, any thoughts about the ultra gauge in general?
bcvetter is offline   Reply With Quote Quick reply to this message
Unread 08-23-2013, 03:20 PM   #2
86cj74.2L
I have a scangaugeII in my Saturn and love it.
86cj74.2L is offline   Reply With Quote Quick reply to this message
Unread 08-29-2013, 02:46 PM   #3
bcvetter
No one else?
Unread 08-29-2013, 03:09 PM   #4
Darnice
Never seen that before, looks nice, if it works on a WJ. For $60, might be worth a try. I think there is an issue where the power is on the ODBII connector on the jeeps and it won't power off. Not sure on that but I had a scan gauge 1 and it would never power off.
Darnice is offline   Reply With Quote Quick reply to this message
Unread 08-29-2013, 03:13 PM   #5
ChrisHager
ChrisHager's Avatar
If I don't turn the switch off, my Kiwi Bluetooth adapter plugged into my OBDII port will stay on as well...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 08-29-2013, 03:42 PM   #6
bcvetter
http://www.ultra-gauge.com/customer_....php?article=7
Just found this. Thanks for the input. I think I'll go for it and post pics.
Unread 08-29-2013, 06:45 PM   #7
Darnice
I was reading the forums for the gauge. Turns out the new version 1.2 can sense that the ignition is off and will power itself off. Note your link was refering to ver 1.0. So I suspect it will work. Too bad the cable comes out the side and not the back of the gauge making it harder to mount in the cubby hole below the HVAC controls.
Unread 08-29-2013, 06:58 PM   #8
gcjeeping
gcjeeping's Avatar
I wouldn't put it in the cubby. Too far to look down at it.
I just use my phone, elm327 and the torque app.
__________________________________________________ _________
-GCJEEPING's build/mod thread-IT'S A GREEN THING...
gcjeeping is offline   Reply With Quote Quick reply to this message
Unread 08-29-2013, 08:00 PM   #9
bcvetter
I measured for the cubby and it should fit even with the cable on. I do wish that there was a cleaner place to mount it but I don't like anything on my windshield or dash.
Unread 08-29-2013, 08:42 PM   #10
TJSWJ
Ive got the ug, worth every penny.
[URL="http://www.jeepforum.com/forum/f197/tjs-01-wj-build-thread-1023461/"]4.5" Claytons, 33's, 231hd, locked, and more. Click here for details[/URL]
TJSWJ is offline   Reply With Quote Quick reply to this message
Unread 08-30-2013, 04:55 AM   #11
86cj74.2L
If its like the scangauge. Knowing the trans temp would be worth it.
I figured out the PID for trans temp on my Saturn. I didn't look on their site for it for the WJ. By now somebody should have figured it out.
Unread 08-30-2013, 05:34 AM   #12
georged
Can it be used at the same time the unit from my insurance company that tracks my driving habits is plugged in? It would probably require a piggyback plug if that is available.
georged is offline   Reply With Quote Quick reply to this message
Unread 08-30-2013, 07:46 AM   #13
rebelbowtie
It'd def have to be piggy backed, they make cables to hook up more than one device to the DLC
Anywho here is mine in my XJ and T4R, its worth every penny IMO and has already paid for itself in beer since I can check and clear my friends codes.
rebelbowtie is online now   Reply With Quote Quick reply to this message
Unread 08-30-2013, 09:25 AM   #14
rfritz7
Will the Ultra Gauge tell me my transmission temp on my 04 wj 4.0?
rfritz7 is offline   Reply With Quote Quick reply to this message
Unread 08-30-2013, 09:30 AM   #15
rebelbowtie
No, not currently.
