The Ultimate Death Wobble Fix Thread (Phase 2) - Page 2 - JeepForum.com
View Poll Results: What was the cause/fix for your death wobble?
Tie Rod Ends 33 38.82%
Track Bar Bushings 40 47.06%
LCA Bushings 6 7.06%
Tire Balance 12 14.12%
Alignment 15 17.65%
Tires Themselves 12 14.12%
Power Steering 6 7.06%
Multiple Choice Poll. Voters: 85. You may not vote on this poll
post #16 of 61 Old 12-28-2011, 09:41 AM
RiverMCK
2003 WJ
I had DW on my recently acquired 03 WJ (wife's old rig). Upper TRE was shot, steering gear box was dying and tires were on their way out. Replaced those three components and got an alignment and now the DW is gone. Note: ball joints were good and track bar bushings were good. My hunch is that the shotty steering components allowed for the steering slop, and the tires being badly worn and out of alignment amplified everything into the dreaded DW.
RiverMCK is offline
post #17 of 61 Old 12-30-2011, 05:04 AM
Vaschetty
Originally Posted by Vaschetty View Post
Hi Guys.
This is a great thread - thanks!!
I am fighting death wobble right now. I just fitted 2 inch spring spacers (as a temporary lift until I can afford 3" IRO) and now I have instant death wobble (never had it before). I have checked for play in all suspension components and the only thing that I could really find was excess play in the TRE on the knuckle end of the drag link. Initially I discounted this as the cause because everywhere else on the internerd I have read about DW nobody has mentioned TREs. This is the first time I have read about it - thanks to this pole I will now change the TRE and hopefully conquor the dreaded DW - then I will vote.
A big thanks from me!!!
Ok so my tie rod end didn't arrive today (thanks a lot Australia Post - 1 day guaranteed delivery my ball bag!!!). I did get new tyres and a wheel alignment though and I can't make a death wobble happen now!!
I upgraded tyres from 235/65/17 HTs to 265/70/17 chunky ATs (ie. 29s to 32s).
Alignment before:
Caster 10*
L: +3*22'
R: +4*02'
K.P.I. 10*
L: +11*19'
R: +10*47'
Camber
L: -0*56'
R: -0*18'
Individual Toe:
L: +0.2mm
R: +1.2mm
Total Toe
: 1.3mm
Setback
: +0*23'
Included Angle 10*
L: 10*27'
R: 10*31'
Alignment After:
Caster 10*
L: +3*22'
R: +4*02'
K.P.I. 10*
L: +11*19'
R: +10*47'
Camber
L: -0*49
R: -0*25'
Individual Toe:
L: +0.7mm
R: +0.6mm
Total Toe
: 1.3mm
Setback
: +0*22'
Included Angle 10*
L: 10*27'
R: 10*31'
I'm not convinced that this has cured my death wobble. I think that the bigger, chunkier tyres absorb the road undulations and any attempt of DW to try and start. I can still feel the steering wheel flutter every now and then but it dies away very quickly.
I haven't voted because I'm not convinced I have cured DW. I still have a shot TRE, shot steering damper, 4 shot shockies, stock track bar and bushes and very flexy stock control arm bushes. I think I have only masked DW for now but at least I'll be able to drive 5 hours up the coast tomorrow.
My theory is that DW is caused by too much play in the whole front end setup. There may be one single item that, when replaced, reduces the amount of play in the front end enough to not allow death wobble to happen, it may require a combination of parts to be replaced. My theory anyway, for what it's worth.
I hope my story helps and good luck...
Vaschetty is offline
post #18 of 61 Old 01-01-2012, 04:35 PM
alwaysHI
2003 WJ
TRE's and loosening&re-torquing the control arms to the new lift height fixed my DW.
Bronson = 21 yrs. old
BUILT, NOT BOUGHT - WORKED HARD FOR, NOT KISSED MOMMY/DADDYS A** FOR!
Build Thread -
SOLD
alwaysHI is offline
post #19 of 61 Old 01-05-2012, 03:15 AM
Vaschetty
I didn't loosen my control arms when I lifted. I might try that tomorrow. Thanks!
On a positive, just travelled 500kms up the coast and back and not a single DW.
post #20 of 61 Old 01-05-2012, 11:30 AM
thisguyhasadd2
ditto on retorq control arm probably a good idea.
mine would happen at 55-60 but wouldnt under that. i replaced the stock ss of 104k that i bumped installing the lift which leaked a couple of a drops. turned out to cause a two inch air pocket and gave me the DW
2002 Overland - 4" rc -255/75/17/Jk Moabs
1982 Yamaha XT200J- dead, rebuild winter
Colorado Jeep Club Member#259
thisguyhasadd2 is offline
post #21 of 61 Old 01-05-2012, 03:01 PM
Upside
I had DW after installing 3/4 spacers on my 2" lift springs. The front tires were getting fairly thin and I'm guessing the cases were not very round. The TREs and ball joints have 112K on them. In order to be able to drive the Jeep I swapped the tires front to back (the rear tires have quite a bit more tread) when I installed my new shocks and haven't had a recurrence of DW. The TREs are still worn out but swapping the tires masked the problem for now. I am going to buy new Moog TREs next week and plan on buying new tires this spring.
I don't think you are supposed to be able to easily rotate the drag link or TRE link which is why I think they are worn.
Upside is offline
post #22 of 61 Old 01-07-2012, 05:38 AM
leadsled jeep
Forgive this Jeep Noob but what is a TRE? Thanks!!
Chris
'02 Overland 190k+ miles. 2.5" lift w/springs. All Control Arms upgraded, dual Addco sways.
leadsled jeep is offline
post #23 of 61 Old 01-07-2012, 07:55 AM
StrokedWJ
StrokedWJ's Avatar
Tie rod end
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #24 of 61 Old 05-25-2013, 04:03 PM
MPmedic
Tj
Chasing causes of DW now, Thank goodness for the three day weekend! This is already frustrating...
MPmedic is offline
post #25 of 61 Old 05-25-2013, 06:35 PM
WJ2000
Sorry I cant vote, but I've never had DW.
2000 WJ 4.0 NEW 4.6 stroker. W/ 4'' Tera Flex Long arm kit, KING 2.5s w/res front,2.5 Kings w/res Rear,Tom wood front drive, 33 x 15s KM2s, Bassett 15'x8 ,fully addjustible Tera flex Track bar, IRO 3link rear, EBC Dippled & sloted front disks, EBC green stuff pads, Iceland off road fender flairs''.
WJ2000 is offline
post #26 of 61 Old 09-25-2013, 05:35 PM
Jer25
My old man has a 2000 XJ and I borrowed it once and got the death wobble at 70mph. HOLY ****! Scared the hell out of me. If you keep it under 55mph, its fine.
Maybe I'll crawl under it and see if some things stick out as loose or worn.......I'm sure there will be a few things at 132,000mi.
Jer25 is offline
post #27 of 61 Old 09-28-2013, 01:40 PM
mikeyc1821
All new tre for me and they never even showed any play. Just replaced them as thats all I had left to replace.
mikeyc1821 is offline
post #28 of 61 Old 04-27-2015, 10:18 PM
Hightower718
Question to those of you that have solved this problem.
I feel lots of movement In the steering wheel and can only get it to dw at low speeds 30-35 over continuous bumps.
? 3in IRO
?tires balanced and fairly good cond.
?New track bar w/hard bushings
?Drag link tre's -New
?Ball joints are good
?tre's are "good" as stated by midas and the have no left/right play only twisting
?alignment done
The lca bushings are cracking and I can twist and move them by hand.
How many of you found this lca's to be the problem?
Thanks!
Hightower718 is offline
post #29 of 61 Old 04-27-2015, 10:44 PM
Hightower718
Maybe the steering gear is out? There looks to be a leak maybe and I can move the shaft easly with my hand.
post #30 of 61 Old 04-28-2015, 02:33 AM
cNagy
Hightower
Lcas can most definitely cause dw
cNagy is offline
The Ultimate Death Wobble Fix Thread (Phase 1) 00JGC00 WJ Grand Cherokee Forum 76 09-19-2016 07:15 AM
Death Wobble!! DailydrivenWJ WJ Grand Cherokee Forum 4 01-20-2011 12:00 AM
Death Wobble? sideshobob65 WJ Grand Cherokee Forum 16 01-06-2011 05:41 AM
death wobble still there ive done everything JkTheItalianoWJ WJ Grand Cherokee Forum 31 11-30-2010 09:13 PM
Mean Death Wobble HELP!?!?! JkTheItalianoWJ WJ Grand Cherokee Forum 16 07-22-2010 10:22 PM
