The Ultimate Death Wobble Fix Thread (Phase 2) - JeepForum.com
View Poll Results: What was the cause/fix for your death wobble?
Tie Rod Ends 33 38.82%
Track Bar Bushings 40 47.06%
LCA Bushings 6 7.06%
Tire Balance 12 14.12%
Alignment 15 17.65%
Tires Themselves 12 14.12%
Power Steering 6 7.06%
Multiple Choice Poll. Voters: 85. You may not vote on this poll
post #1 of 61 Old 02-02-2011, 01:01 PM Thread Starter
00JGC00
Exclamation The Ultimate Death Wobble Fix Thread (Phase 2)
As promised, here is the final result...
Death Wobble seems to be a plague that we all fear and can't stand. There are a million threads all over the place about it and for someone who is suffering from it, you will probably spend a lifetime just reading about how to get rid of it.
The purpose of this thread is to help sufferers of DW by giving them a head start in resolving the problem.
In this thread I compiled possible causes of DW:
http://www.jeepforum.com/forum/f310/...e-1-a-1154736/
For those of you who have experienced and solved death wobble, please "vote" in this poll what it was that fixed it for you. The idea here is that the most common/likely causes of DW will become visible in the poll. That way sufferers have a starting point and can then work down the list until they fix their death wobble!
The method is flawed a little because once you vote, you're done and if you get DW again for a different reason, you can't really vote again. Hopefully despite the flaws, the ending result will still work and be beneficial to everyone!
I made the poll multiple choice so that those situations can still be captured.
"The" Matt | '00 Limited WJ | "The White Wolf" aka "Willow" aka "Cool Whip" aka "Sweet 'N Low" aka "AKA"
Utah JeepCrew #39 | Club Matt #1
December '11 GCOTM | Build: http://www.jeepforum.com/forum/f197/life-times-979511/
00JGC00 is offline
post #2 of 61 Old 02-02-2011, 01:06 PM
RockMonster
tj and xj's included? or just wj?
God... my spelling sux.... +++++++++++++++++++++++OIIIIO+++++++++++++++++++++ ++++
RockMonster is offline
post #3 of 61 Old 02-02-2011, 01:09 PM Thread Starter
00JGC00
Good question. Because the steering and suspension systems are somewhat related I suppose other Jeeps wouldn't hurt. No leaf spring fronts though.
00JGC00 is offline
post #4 of 61 Old 02-02-2011, 01:11 PM
orb
2003 WJ
Haven't wobbled yet with my new tires, we'll see how long that holds up. Drove about 250 miles last weekend and mostly on the highway so that is promising.
For the newcomers, shop I took it to said the tires caused it and it has only happened once.
2003 4.0L, OME HD Springs, OME Nitro Shocks, Rancho SS, 265/70R16 General Grabber AT2s
orb is offline
post #5 of 61 Old 02-03-2011, 06:50 PM
vdubracer33
my 00 grand cherokee had a severe death wobble. i replaced the steering stabilizer and it still had it. i went on ebay and bought all the tierods and balljoints. come to find out it was all a waste of money because i just needed the track bar to be replaced
vdubracer33 is offline
post #6 of 61 Old 02-03-2011, 09:24 PM
bigV
bigV's Avatar
I got death wobble on my old TJ due to a bent tie rod, I was running 35" MTR's on it and never had issues other than that. After I lifted my WJ and slapped new 32" KM2's I had a slight wobble, adjusted the toe in to 1/8" and it drives great
High Desert 4 Wheelers
bigV is offline
post #7 of 61 Old 07-09-2011, 10:20 PM
SloLearner
A few months back I installed a JKS body lift, MML, and 1" spacer. Death wobbles ever since. It started a lot less violent at first..and I got lazy and didn't do an alignment for a couple weeks. When I got the alignment..the toe was way off and they adjusted that which helped a lot..but didn't fix it. I then purchased cam bolts to adjust caster which also helped..but didn't fix it. I do have uneven wear on my tires and suspect they may be contributing. And my shocks are prolly up for replacement too.
Here's my opinion...my jeep was flawless before the lift...I don't care if my tires r worn uneven or any other thing that was the same before the lift. Obviously the general consensus on DW is completely due to geometry and play/slack in the system (due to subpar geometry im assuming).
When i am at lower speeds and turn sharply (riding through my neighborhood) I can feel the slack in my steering, mainly when I hit bumps, potholes, etc...It feels like I should just be able to sneak under the front end and tighten something that is extremely loose but can't find it. That same slack/play at 46-50MPH is obviously what makes a "power-though" zone unless I wanna slow down and try again....
Anyone else's thoughts?
SloLearner is offline
post #8 of 61 Old 07-26-2011, 01:02 AM
ksmith38a
I am fighting the death wobble just now. '02 car stock suspension, no changes, no lift.
So far I have replaced;
Lower track arms
Upper track arms + bushes on axle
Track bar
Shock absobers
Steering damper
Alignment has been checked and set and checked and set again but it still does it.
I can go for days without it and the hit an insignificant bump and it sets the wobble going.
Running out of parts to change!
ksmith38a is offline
post #9 of 61 Old 07-26-2011, 05:47 AM
alwaysHI
2003 WJ
ksmith, check your ball joints.
i voted track bar bushings, since thats what caused mines
alwaysHI is offline
post #10 of 61 Old 07-26-2011, 06:49 AM
tsconver
2003 WJ
not sure of the value of this poll as DW is rarely just one cause and is usually due to cummulative wear on many components.
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
A few goodies
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
2006 Red Liberty
Wife's ride, pretty stock
tsconver is offline
post #11 of 61 Old 07-27-2011, 01:52 AM
ksmith38a
Wj
I knew I had left something off the list .
Upper and lower ball joints on the steering knuckles done on both sided.
My track bar was shot too.
As someone else said its not just always one part.
Every time I change a part it seems ok for a couple of weeks then its back!
post #12 of 61 Old 07-27-2011, 02:23 AM
MEinSoCal
hows the condition of your tires? i know for me, once instance of death wobble was caused by some badly worn out mud terrains, that were so out of balance, it wasn't even funny. once i got a set of new tires, which i really needed and was overdue for, my death wobble went away.
since you're stock, i'm assuming you don't have an adjustable track bar. in my case, my JKS adjustable track bar caused lots of problems whenever the jamb nut would come loose, no matter how hard and often i tightened it. i ended up having the jamb nut tack welded in placed, and that solved that problem of death wobble too.
MEinSoCal is offline
post #13 of 61 Old 12-28-2011, 05:59 AM
Vaschetty
Hi Guys.
This is a great thread - thanks!!
I am fighting death wobble right now. I just fitted 2 inch spring spacers (as a temporary lift until I can afford 3" IRO) and now I have instant death wobble (never had it before). I have checked for play in all suspension components and the only thing that I could really find was excess play in the TRE on the knuckle end of the drag link. Initially I discounted this as the cause because everywhere else on the internerd I have read about DW nobody has mentioned TREs. This is the first time I have read about it - thanks to this pole I will now change the TRE and hopefully conquor the dreaded DW - then I will vote.
A big thanks from me!!!
Vaschetty is offline
post #14 of 61 Old 12-28-2011, 07:05 AM
RedlegWJ
I didn't vote, because I agree, it is usually more than one factor. I have had parts go bad without DW, that I had replaced during a bout with DW. Even with all new parts, you could still feal it want to "try". Biggest difference was after toe and castor were adjusted. Waited on doing those til all parts were replaced for the most accurate alignment.
Gray 99 Laredo with '04 driveline wap. Tons of fun coming soon. Steel bumpers. 5 1/2" IRO coils, IRO adj. track bar. Rancho RS9000 Addco rear sway. 2"x.250" DOM long arms with johny joints. Custom A-arm with ball joint delete (J-joint). JK Moab wheels/ 33x 12.5 x 17 Cooper SST. Bushwacker Flares.
RedlegWJ is offline
post #15 of 61 Old 12-28-2011, 08:13 AM
tbone1004
Didn't vote because my cause wasn't up there. Mine was caused by the adjustable trackbar nut shaking itself loose. Put locktite on it and it's gone
tbone1004 is offline
The Ultimate Death Wobble Fix Thread (Phase 1) 00JGC00 WJ Grand Cherokee Forum 76 09-19-2016 07:15 AM
Death Wobble!! DailydrivenWJ WJ Grand Cherokee Forum 4 01-20-2011 12:00 AM
Death Wobble? sideshobob65 WJ Grand Cherokee Forum 16 01-06-2011 05:41 AM
death wobble still there ive done everything JkTheItalianoWJ WJ Grand Cherokee Forum 31 11-30-2010 09:13 PM
Mean Death Wobble HELP!?!?! JkTheItalianoWJ WJ Grand Cherokee Forum 16 07-22-2010 10:22 PM
