The Ultimate Death Wobble Fix Thread (Phase 1) - JeepForum.com
 1Likes
post #1 of 77 Old 01-17-2011, 10:43 AM Thread Starter
00JGC00
Death Wobble seems to be a plague that we all fear and can't stand. There are a million threads all over the place about it and for someone who is suffering from it, you will probably spend a lifetime just reading about how to get rid of it.
I propose that we put together a thread that will give sufferers a head start. What I would like to do is have anyone and everyone who has EVER had death wobble, please post in here every last possible cause of death wobble. (I guess I'm really hoping there aren't more than 20 causes - you'll see why). Once we have a solid, comprehensive list of DW causes, I'll make a poll with the causes listed out. Then anyone who has solved DW, will "vote" on what it was that fixed it for them. The idea is that the most common causes/fixes will be visible in the poll and then new DW victims have a starting point and can go through the list in a "most likely" order and start eliminating variables...
What do you think?
Current List:
Tie Rod Ends
Track Bar Bushings
LCA Bushings
Tire Balance
Alignment
Tires Themselves
Power Steering
"The" Matt | '00 Limited WJ | "The White Wolf" aka "Willow" aka "Cool Whip" aka "Sweet 'N Low" aka "AKA"
Utah JeepCrew #39 | Club Matt #1
December '11 GCOTM | Build: http://www.jeepforum.com/forum/f197/life-times-979511/
00JGC00 is offline
post #2 of 77 Old 01-17-2011, 10:49 AM
SilverRubicon04
SilverRubicon04's Avatar
Xj
OutStanding Idea!
Never do anything that you wouldn't want to explain to the paramedics. ~Author Unknown
SilverRubicon04 is offline
post #3 of 77 Old 01-17-2011, 12:35 PM
orb
2003 WJ
Awesome because I got it for the first time last night. Scary as ****! Taking it into HCP4x4 tomorrow so hopefully they can straighten it out. I'll post back with the results.
2003 4.0L, OME HD Springs, OME Nitro Shocks, Rancho SS, 265/70R16 General Grabber AT2s
orb is offline
post #4 of 77 Old 01-17-2011, 01:18 PM Thread Starter
00JGC00
Cool, thanks!
00JGC00 is offline
post #5 of 77 Old 01-17-2011, 09:57 PM
TJSWJ
in order of how I experienced them. 1. Bad tre's 2. Bad track bar bushings 3. bad lower control arm bushings. 4. tire balance off. 5. Was my own noob mistake off using a drop pitman arm at 4in of lift without using a track bar drop bracket. Major bumpsteer leading to dw.
TJSWJ is offline
post #6 of 77 Old 01-17-2011, 10:27 PM
SplitNail
HAHA I remember when you had all your DW problems. It was just the DPA. Good times.
Most of the time its bad TREs in my cases.
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
post #7 of 77 Old 01-17-2011, 10:34 PM
alifted4x4
2009 JK Wrangler
Never had it, hope I never get it!!!!
2000 WJ 6 1/2" lift,IRO Coils, IRO Front ADJ Long Arms, Clayton Rear Long Arms, Bilstein 5100 Shocks, JKS Track bar, JKS Bar Pins, K & N FIPK, 265/75/16 Nitto Terra Grapplers, 1.5" Wheel Spacers, Addco Rear Sway Bar, IRO Rear Sway Bar Links, Flowmaster 40,2002 Cluster to be continued.....
alifted4x4 is offline
post #8 of 77 Old 01-17-2011, 10:40 PM
TJSWJ
Haha yes it was. All I can say is thanks to you and JF for the help. its crazy problems like dw that I can justify purchasing a membership for. I encourage anyone who hasn't bought a membership to get one to help support the cause.
TJSWJ is offline
post #9 of 77 Old 01-17-2011, 11:35 PM
Bama_WJ
Bama_WJ's Avatar
It was bad tie rod ends that caused mine.
Kevin's hard track bar bushings helped out, but it was ultimately bad TREs.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #10 of 77 Old 01-17-2011, 11:38 PM
sinbad85
Mine was to much caster (7 deg to 5 deg) after a 4 in lift.
2001 WJ 4.7L-selec-trac/4.5" Teraflex springs\IRO Long arms\Iro adj rear LCA/Bilstien 5100 series shocks/ IRO steering Equalizer/|265/75/16 Goodyear Dura-Tracs on Stock rims\Rear Tube Bumper with carrier|sliders|mopar skids.
sinbad85 is offline
post #11 of 77 Old 01-18-2011, 12:07 AM
phant0omx
2012 WK
mine was bad tres and/or loose track bar, body mount side.
phant0omx is offline
post #12 of 77 Old 01-18-2011, 02:27 AM
U2Fans
Thank god i've never had to deal with dw....
The "Other" Voice of Reason
Who's got some sliders they want to sell me???
U2Fans is offline
post #13 of 77 Old 01-18-2011, 09:28 AM Thread Starter
00JGC00
Ok, list updated (see post 1). Any other causes you've experienced or heard of?
I have another question. How similar are ZJ suspensions to WJ's? Would it be better to post the DW (phase 2) thread in here or in the general GC forum?
00JGC00 is offline
post #14 of 77 Old 01-18-2011, 09:54 AM
SplitNail
What does phase 2 consist of? Going to another galaxy??
post #15 of 77 Old 01-18-2011, 09:58 AM Thread Starter
00JGC00
Yes.....that's right......
00JGC00 is offline
death wobble wtf WJtowsM3 WJ Grand Cherokee Forum 4 10-06-2010 06:56 PM
death wobble... AGAIN, PLEASE HELP!! iluvmy03wj WJ Grand Cherokee Forum 7 08-13-2010 07:05 AM
Mean Death Wobble HELP!?!?! JkTheItalianoWJ WJ Grand Cherokee Forum 16 07-22-2010 11:22 PM
Death Wobble BULLITTBUilder WJ Grand Cherokee Forum 2 07-21-2010 07:53 AM
Death Wobble Help!! ljhopp WJ Grand Cherokee Forum 16 06-21-2010 01:02 PM
