Uh oh.... - JeepForum.com
post #1 of 25 Old 04-22-2013, 12:35 PM Thread Starter
rcwj04
Well I finally figured out what was causing the steam from my engine bay.....no bueño. Looks like a new radiator will be in my very near future. How hard are these bad boys to replace on a 4.0?
You forget that most members here don't own a crystal ball to tell you exactly what your problem is, specially with bad pictures that don't say/show much of anything... -Jacko84
Just a 19 year old kid with a Jeep, and broke because of it, and loving every moment.
2004 WJ Laredo 4.0 116k
2" BDS coils & Bilstein 5100's | Addco rear swaybar with energy bushings |
K&N FIPK | glasspack | plasti-dipped badges | 17" moabs | HID's, 245/65/17 Cooper Discover AT3 | Rola rack | Fawkes stand alone shackle tabs | Bed lined interior (what a pain that was)
rcwj04 is offline
post #2 of 25 Old 04-22-2013, 01:07 PM
WJ_allday04
http://www.thepartsbin.com/catalog/?...294962953+9235 $83 plus shipping
Im not sure how hard it is to replace though...
2004 WJ 4.7 - 7in lift
Rustys Long Arms//Rustys f+r springs//Rustys crossmember
CSL RLCA//Poly D30 bushings//IRO A arm
Skyjacker Nitro's//JKS trackbar//242HD+IRO SYE
WJ_allday04 is offline
post #3 of 25 Old 04-22-2013, 01:28 PM Thread Starter
rcwj04
Thanks for link. I was looking at that brand, but thats the cheapest so far. I don't want to go too cheap cause I believe you get what you pay for, yet I also don't want to pay its weight in gold. radiatorbarn.com also had a fairly cheap radiator.
rcwj04 is offline
post #4 of 25 Old 04-22-2013, 06:18 PM
lazyWJ
2006 XK Commander
SPI (spectrum premium) seems to have a good rep. No idea on how hard it is on the 4.0, but it shouldn't be too bad. I did my 4.7 w/hydraulic fan in about 5 hrs, yours should be easier as the hydraulic fan is a PITA.
2004 Imola BMW ZHP
2006 Commander Limited Hemi QD2
"Bought, Not Built"
lazyWJ is offline
post #5 of 25 Old 04-22-2013, 07:18 PM Thread Starter
rcwj04
I ended up ordering a crown from the grand cherokee god (kolak)
rcwj04 is offline
post #6 of 25 Old 04-23-2013, 05:47 AM
adolphhipster
It took me 4-5 hours. It was the worst thing I've done in a while. Good luck and hopefully the one you buy doesn't come with a hole in it. :badluck: with hydraulic fan on the 4.0
adolphhipster is offline
post #7 of 25 Old 04-23-2013, 07:01 AM Thread Starter
rcwj04
I would be beyond pissed if it comes with a hole haha. On a level of 1(oil change to 10(4bt swap) where would you rate this?
rcwj04 is offline
post #8 of 25 Old 04-23-2013, 07:04 AM
adolphhipster
Id give it like a 4 or 5. Its not really difficult just very time consuming and is just a dumb design
post #9 of 25 Old 04-23-2013, 07:11 AM Thread Starter
rcwj04
sounds like I have a very fun weekend ahead of me
rcwj04 is offline
post #10 of 25 Old 04-23-2013, 07:24 AM
ChrisHager
Administrator
ChrisHager's Avatar
Here's my thread that shows how to remove the radiator on the 4.0 (along with other, more in-depth stuff): 2004 4.0 I6 Jeep Grand Cherokee Camshaft, Timing Set, and Lifter Replacement
Here's mailforjon's radiator replacement write up: WJ Radiator Replacement Write-Up w/ Pics
Between those two, you should be golden.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #11 of 25 Old 04-23-2013, 07:34 AM
Crewdude007
How many miles? While you have everything apart, this is a perfect time to replace the water pump if it's old.
Currently Jeepless
2001 XJ - SOLD
2000 WJ - SOLD
Crewdude007 is offline
post #12 of 25 Old 04-23-2013, 07:37 AM
adolphhipster
Also replace the fan relay behind the headlights
post #13 of 25 Old 04-23-2013, 08:22 AM Thread Starter
rcwj04
well I have a '04 so my fuse is in the fuse box so thats not as much of a pain as the earlier wjs
rcwj04 is offline
post #14 of 25 Old 04-23-2013, 08:24 AM
adolphhipster
Oh didn't realize they moved the fan relay. Well lucky you haha
post #15 of 25 Old 04-23-2013, 01:08 PM Thread Starter
rcwj04
Only 108k I was thinking of doing the water pump but I don't think I really need too
rcwj04 is offline
