U-nuts for tow hooks. where to find - JeepForum.com
post #1 of 10 Old 03-13-2014, 02:31 AM Thread Starter
Locutus
2014 WK
Wj U-nuts for tow hooks. where to find
Just got some tow hooks and there are no u nuts included. Can someone point me to a supplier or do any of you guys have any spares?
Any help is appreciated
If it ain't broke, fix it till it is
Locutus is offline
post #2 of 10 Old 03-13-2014, 04:30 AM Thread Starter
Locutus
2014 WK
got them from Kolak
Locutus is offline
post #3 of 10 Old 03-13-2014, 07:35 AM
Thomahawk
2006 XK Commander
Clips and fastners dot com got them
Buildthread
Thomahawk is offline
post #4 of 10 Old 03-13-2014, 07:37 AM
ChrisHager
Administrator
ChrisHager's Avatar
I haven't tried them yet but here are a couple quotes from a different thread. This option may be just what you need...
Originally Posted by Justinb306 View Post
Just did the install. I was missing the 2 u nuts and 2 bolts to go with them. I couldn't find a metric u nut with the correct depth to match the others. Most metric u nut depths that match the OEM bolts are 19mm and you need roughly 28mm depth. I went with sae thread Napa Balkamp u nuts part #665-1961 package of 3 you only need 2 of them. They are 3/8 - 16 screw size and just picked up 2 sae 3/8 - 16 Grade 8 bolts and washers from them. I think the bolts were 1 1/4 length. You can go longer if they don't have the correct length.
A GM part number comes up for the u bolts that matches the Jeep OEM metric bolts with the correct depth. The number comes up in their computer but they said no longer available.
Originally Posted by ChrisHager View Post
Good information!
http://www.napaonline.com/Catalog/Ca...961_0361079104
Dimensions : Panel Range - .05" - .2", Center Of Hole To Panel Edge - 1 1/8"
Manufacturer : Auto Fastener Group, Inc.
Manufacturer Part Number : 46029
Material Type : Steel
Mounting Hole Diameter : 3/8"-16
Package Quantity : (1) Nut
Style Name : Extruded U-Nut
Thread Size : 3/8"-16
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #5 of 10 Old 03-13-2014, 01:34 PM
Burns95
Any "True Value" hardware store should have them.
Burns95 is offline
post #6 of 10 Old 03-13-2014, 06:20 PM
rdkendrick
2003 WJ
Lowes has them, too.
Sent from my iPad using electrons
rdkendrick is offline
post #7 of 10 Old 03-13-2014, 11:31 PM
Johnyre
They are also Ace hardware. same store
As I roll down the trail,I hope my traction will not fail.But if I spin & begin to slide,please dear lord protect my ride
https://
http://fortcollinswheelers.com
Johnyre is offline
post #8 of 10 Old 03-14-2014, 06:02 AM
ChrisHager
Administrator
ChrisHager's Avatar
Are you sure? Notice how deep the required u-nuts are? The way I understand it, they aren't your standard u-nut that you can grab anywhere...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #9 of 10 Old 03-14-2014, 08:15 AM
rdkendrick
2003 WJ
Well, I didn't take any out of the package to measure them, but it said it had the same measurements as the rock rail mounts I was looking for. I was only browsing at the time, but they looked just like what I had bought from www.clipsandfasteners.com.
post #10 of 10 Old 03-14-2014, 08:49 AM
ChrisHager
Administrator
ChrisHager's Avatar
If you buy from Lowes/Menards/Ace, be sure the center of the hole to the edge is deep enough...
It looks like this may work from ClipsAndFasteners:
Extruded U Nut M10-1.5 Screw Size - GM
Extruded U Nut
Phosphate
M10-1.50 Screw Size
Panel Range: 1.0mm-6.0mm (.040"-.230")
Center of Hole to Edge: 19mm (3/4")
Replaces GM: 11500662, 22531616
25 Per Package
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
