Tyre pressure - JeepForum.com
post #1 of 4 Old 10-25-2013, 04:32 AM Thread Starter
drmadcat
2006 WK
Tyre pressure
Sorry to bring this up again
I have Mickey Thompson STZ 245 70 16 on my WJ
The tyre place told me to put 40psi in which i thought they should have 33psi, when i went and checked them they had 44psi in. When they have 33psi in they look too flat so no real idea what pressure to run them at.
drmadcat is offline
post #2 of 4 Old 10-25-2013, 05:24 AM
Duh
I like 35 cold in my 265/70r17. Wont pass forty hot. Nice good print, minimal bulge.
Duh is offline
post #3 of 4 Old 10-25-2013, 07:40 AM
ChrisHager
Administrator
ChrisHager's Avatar
Since you don't have any information listed about your WJ, I'll split the difference on the weight. Feel free to recalculate if you need to adjust the weight estimations.
WJ Weight: 4200lbs
Cargo: 400lbs
Max Load (for your listed tire): 2910
Max PSI (for your listed tire): 80
4200 + 400 = 4600 overall weight
4600 / 4 = 1150 lbs per tire
1150 x 1.15 (15% margin of error) = 1322.5 lbs per tire
1322.5 / 2910 = 0.454 (indicating you are using 45% of the tire's max weight)
0.454 x 80 = 36.357
Calculations show 36 psi is probably your ideal pressure to aim at. Another way to be sure is to chalk test the tire.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is online now
post #4 of 4 Old 10-25-2013, 11:37 AM Thread Starter
drmadcat
2006 WK
WJ Weight: 4200lbs
Cargo: 400lbs
0.454 x 80 = 36.357
Thank you for that chart
drmadcat is offline
