Turn signals don't work but hazards do - JeepForum.com
post #1 of 5 Old 07-29-2014, 04:11 PM Thread Starter
Spyder328
Ok so I have been searching this for hours and I am seeing conflicting answers. My turn signals stopped working, the blinker lights on the dash aren't lighting, and the turn signal "clicking" isn't there. My hazards do work, the blinker lights on the dash work with the hazards, and the "clicking" is there when the hazards are on. All my lights work and my AC/heater are working. Everything works except the turn signals. I pulled the flasher relay out and I can't find any cracks in the solder joints, even with a magnifying glass. When I have the flasher relay out the hazards do not work, but when I put the relay back in the hazards work again. The fuse is good as well. I don't know what to do now....
2000 WJ Laredo, 255/70R16, 2.5" front and 2" rear BB, 1.25" wheel spacers
Spyder328 is offline
post #2 of 5 Old 07-29-2014, 06:28 PM
narnwv
narnwv's Avatar
It's the flasher relay.
Yes, I read your whole post. Trust me, it's the flasher relay.
~Aaron
narnwv is offline
post #3 of 5 Old 07-29-2014, 07:23 PM Thread Starter
Spyder328
I ended up taking a soldering iron and re-soldered all of the connections on the flasher relay and its now working. Should have done that before I posted Thanks for the reply tho
post #4 of 5 Old 09-01-2014, 07:20 PM
rjbdaddy
Signal & Hazards not working
Sorry I am having trouble posting a new thread...changed grill assembly on 1998 Grand Cherokee Laredo and have headlights and running lights but no signal lights...had right originally then neither.
Check fuse, and changed flasher...
Any ideas for a mechanic wannabe?
rjbdaddy is offline
post #5 of 5 Old 09-01-2014, 07:43 PM
rdkendrick
2003 WJ
Originally Posted by rjbdaddy View Post
Sorry I am having trouble posting a new thread...changed grill assembly on 1998 Grand Cherokee Laredo and have headlights and running lights but no signal lights...had right originally then neither. Check fuse, and changed flasher... Any ideas for a mechanic wannabe?
Yes. Ask the ZJ guys.
Sent from my iPad using Electrons
rdkendrick is offline
