Turn signal question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Turn signal question
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Stainless Steel Door Hinge PinsPoly Door Hinge Bushings
Unread 10-28-2013, 06:17 PM   #1
kumijia
My left turn signal works when it wants too. I could use it on one turn, and the next turn it won't work. Should i assume it's the switch/lever? I figured i'd asked on here, before buying a new one, in case it could be something else?
kumijia is offline   Reply With Quote
Unread 10-28-2013, 07:03 PM   #2
rdkendrick
2003 WJ
Sounds right, to me. That would be my first guess.
Sent from my iPad using my fingers
rdkendrick is offline   Reply With Quote
Unread 10-28-2013, 07:05 PM   #3
dadamets
check the flasher. I recently had the same issue and I put more solder on the joints and have been problem free on this issue.
dadamets is offline   Reply With Quote
Unread 10-28-2013, 09:33 PM   #4
SirSilvia
I had an old nissan and it did the same. i took the level off and opened it up. the contacts inside were gummed up/corroded. not sure if you can do that to jeeps though.
actually, looks like you can
2002 Jeep Grand Cherokee Limited V8
SirSilvia is offline   Reply With Quote
Unread 10-29-2013, 02:10 PM   #5
kumijia
Cool i'll try that first.
Unread 10-29-2013, 08:15 PM   #6
dadamets
Before you go and pull out the switch, put on the four way flashers and then turn them off. Do this a few times. Proceed to then check if your left blinker will work? If it does it is the flasher which is located below the dash. Do a search and you will see exactly where it as as well as how you can repair it yourself if you are so inclined.
Unread 10-30-2013, 06:44 PM   #7
kumijia
I was reading other post about this problem or similar. There is several references to a write up about it. I found several posts, but not the write up....does anyone know the link or what to search that will pull that write up?
Unread 10-30-2013, 06:56 PM   #8
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
Don't know what write up you are talking about, but I do have a switch for sale for $10 plus mailing cost if you need it.
http://www.jeepforum.com/forum/f128/...04-wj-1735762/
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
www.militaryjeepers.com lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline   Reply With Quote
Unread 10-30-2013, 09:51 PM   #9
dadamets
Try this
http://www.jeepforum.com/forum/f310/...guide-1167239/
Unread 10-31-2013, 05:39 AM   #10
kumijia
I did this this morning and the left turn signal never started to work, am I safe to rule out the flasher and say its the switch?
Unread 10-31-2013, 06:41 AM   #11
michiganmaveric
Got Beer?
2011 JK Wrangler
No, still could be the flasher. They are cheap so that is where I would start.
Lifetime member #13
Unread 10-31-2013, 05:07 PM   #12
MuddyWJ
Pull the relay out and check the contacts for cracks. I just resoldered mine a couple days ago and now I have a left signal after 2 years.
MuddyWJ is online now   Reply With Quote
Unread 10-31-2013, 07:07 PM   #13
Duh
Chrysler is known for making pretty crappy multifuntion switches (turn signal switch). I replace them all the time in wj's, wk 's and even more often in the vans. If you have a multimeter its pretty easy to tell if the signal is coming from the switch or not, you can access the switch connector by removing the steering column trim (screws on underside)
Duh is offline   Reply With Quote
Unread 10-31-2013, 08:19 PM   #14
michiganmaveric
Got Beer?
2011 JK Wrangler
Not to say you are wrong, but I have owned Chrysler products, Dodge and Jeep, since 1989 and never had a problem with the switches.
Lifetime member #13
Unread 11-01-2013, 04:39 AM   #15
Duh
I do about 1 a week at work. But i also do 5-10 vehicles a day, and there are 6 other techs in this one chrysler shop. Its all opinion on whats considered a lot i guess.
