turn signal and emergency flasher not working - JeepForum.com
post #1 of 9 Old 05-21-2013, 05:24 PM Thread Starter
FordExplorer
It was working alright then all in the suddenly it stop . What is weird is when i turn on my light the left hand signal stay on doesn't flash . Any Suggest what is going on?
2000 Jeep Grand Cherokee 4.0 160,000 miles
FordExplorer is offline
post #2 of 9 Old 05-21-2013, 05:33 PM
car5car
2002 M-38
flasher $50 from dealer and Advance auto, $12 ebay
http://www.ebay.com/itm/99-04-Grand-...e97935&vxp=mtr
01 XJ 2wd 4.0
car5car is offline
post #3 of 9 Old 05-21-2013, 05:34 PM
imaguy3
the flasher relay could be bad... or a bulb could be burnt out....
When it turns on and stays on, check front and rear.. if all bulbs are lit I'd suspect the relay. If one is out then replace it and see if that helps.
EvilEagle - "Imaguy3 just made everyone in this thread his *****."
imaguy3 is offline
post #4 of 9 Old 05-21-2013, 05:37 PM Thread Starter
FordExplorer
the relay where is located is easy to replace ? thank
post #5 of 9 Old 05-21-2013, 05:54 PM
doityourselfMM
doityourselfMM's Avatar
Combination Flasher is located inside dash, below the instrument cluster, above the driver's feet, to the left of the steering column. For me, it was necessary to remove some of the plastic covers to access the relay. No more than 1 hour to remove and replace. Philips head screwdriver was all I needed.
doityourselfMM is offline
post #6 of 9 Old 05-21-2013, 05:55 PM Thread Starter
FordExplorer
easy to remove and replace or you need to remove lots of things ?
post #7 of 9 Old 05-22-2013, 09:02 AM
doityourselfMM
1) FSM says to disconnect the negative cable. (Up to you. I didn't.)
2) Remove the fuse cover.
3) Lower steering wheel.
4) Gently pry the cluster bezel (below instrument cluster) by each of the four corners. It is held in place by four snap clips. Pull toward you, 'rolling' it over the top of the steering column. Don't scratch the instrument cluster!
5) Remove the one outer and two (?) inner screws that hold the steering column opening cover (below steering column). Pull rearward to disengage the three snap clips.
Yours may differ slightly, but this is the gist of it. The combination flasher is the black relay in the upper middle position of the junction block.
post #8 of 9 Old 05-22-2013, 10:13 AM Thread Starter
FordExplorer
the fuse keep blowing up
post #9 of 9 Old 05-22-2013, 12:22 PM
imaguy3
In your first post you're saying the light is staying on but not flashing. Then in the other you say you're blowing fuses.
Which fuse are you blowing? If it was for the light then you shouldn't have any light at all.
imaguy3 is offline
