Tried to do Spark Plugs today in the 4.7--Didn't happend - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Tried to do Spark Plugs today in the 4.7--Didn't happend
1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,Zone Offroad Body and Suspension Lift Kits, Brackets, Disc
Unread 08-15-2012, 07:30 PM   #16
multmigs
2003 WJ
Originally Posted by 2001WJv8 View Post
i change #8 by reaching through the flipper glass, much easier once i figured that trick out
the who and what now?
multmigs is offline   Reply With Quote Quick reply to this message
Unread 08-29-2012, 09:58 AM   #17
utekking
2014 WK
Just changed my plugs today. Not sure what the gripe over #8 is. I had it out in about 15 minutes. Undid the ground cable and the wire harness that goes over it. Removed the PCV valve connection at the oil fill tube and used a 6" extention and a rachett that has a pivot head on it. When I had it out, I was wondering WTF, that was to easy.....
utekking is offline   Reply With Quote Quick reply to this message
Unread 08-29-2012, 10:12 AM   #18
Double E
2000 Laredo V8
Double E's Avatar
A 2004 thread that lives again....
2000 Laredo 4.7L Selec-Trac. 177K miles, Leather, 245 tires, tow package, crappy CD changer, full size spare, roof cross-rails & sunroof.
Changes & fixes: Rear Addco sway bar & greasble bushings, upgraded headlights, upgraded tail lights, new hood struts (replaced 2X), new rear hatchglass struts, new radiator (replaced 3X), new oil pressure sending unit (replaced 4X), 2 new speed sensors, 2 new door lock actuators, new ignition key cylinder, chrome front tow hooks, Mobil 1 Synthetic 5/30, Purolator Pure One oil filter, EBC slotted & dimpled rotors, EBC Greenstuff pads, new front shocks (replaced 3X), new rear shocks (replaced 2X), new IRO steering stabilizer, new timing chain cover, new water pump, thermostat, new thermostat housing, new high pressure power steering hose, Michelin-X radials, new sunroof assembly, new single-piece lug nuts, new exhaust manifold studs & gasket on driver's side, new Durango alternator. Jeepforum.com sticker, Visit cobaltboatsforum.com when you can!
Double E is offline   Reply With Quote Quick reply to this message
Unread 08-29-2012, 10:12 AM   #19
2001WJv8
1983 CJ7
you described the gripe - plus not being able to really see in there without a mirror to make sure you clean it out before pulling the plug up
yeah no biggie, but still not as easy as the front 6 .... but i'll trade the extra effort every 30k miles for the extra power anyday
James
83 CJ7/SBCv8/4spd
2001WJv8 is offline   Reply With Quote Quick reply to this message
Unread 08-29-2012, 01:14 PM   #20
Merc1973
Exactly, You just need the right tools. I use my snap-on swivel plug socket > 3" extension, swivel > 8" extension.
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline   Reply With Quote Quick reply to this message
Unread 08-29-2012, 01:42 PM   #21
utekking
2014 WK
Thanks for your great insight!!!!
Unread 08-29-2012, 01:44 PM   #22
cuttysark
lol
cuttysark is offline   Reply With Quote Quick reply to this message
Unread 08-29-2012, 02:21 PM   #23
SwissWJ
I'll be changing mine out soon, I'll start with number 8 first get that sob out of the way and hopefully cruise through the rest. Thanks for the tips everyone!
SwissWJ is offline   Reply With Quote Quick reply to this message
Unread 08-29-2012, 02:23 PM   #24
2001WJv8
1983 CJ7
that's what I do, get the one most likely to aggravate you over with then the rest is just "one on one time" with your engine
Unread 09-23-2012, 10:52 AM   #25
jager66
did mine a while ago. Greasing up the O ring on the coil sleeve will help in future.
I replaced the stock with Iridium tipped plugs, so unless there is a problem I don't intend taking them out again.
#8 is a beatch, but I hope never to remove it again.
jager66 is offline   Reply With Quote Quick reply to this message
Unread 09-23-2012, 12:34 PM   #26
Gunrunner23
I hope you have a HO.... Unless you do then you arent suppose to use anything other then copper.
2004 wj limited 4.7
IRO 3in lift with skyjacker hydro
265/75/16 TreadWright Claws
Gunrunner23 is offline   Reply With Quote Quick reply to this message
Unread 09-23-2012, 04:42 PM   #27
narnwv
narnwv's Avatar
You need the correct plugs, otherwise damage can occur.
Sent from my Atari 2600 using JeepForum App
~Aaron
narnwv is offline   Reply With Quote Quick reply to this message
Unread 09-23-2012, 06:50 PM   #28
mjWJ12
I did mine last week.
Also canged the air filter with a lifetime one. Also cleaned the throtle body
(04 WJ Laredo)3" IRO +3/4" front spacers; Custom rear bumper +d-rings; universal front tow hook; plasti-dipped 16" silverblades; premium sliders; custom hi-lift mount; 265/75/16 Cooper Discoverer ATP.
[URL="http://www.jeepforum.com/forum/f197/mjwj12-build-thread-1436508/"]Here is my Build Thread[/URL]
mjWJ12 is offline   Reply With Quote Quick reply to this message
Unread 09-23-2012, 08:16 PM   #29
milresq
HOLY CR@P I did 4 of mine today. Thanks to Oreily's giving me the wrong plugs and having to run back to the store to get the right one's. But mine came right out no problem. When you put them back use dielectric grease. It helps going back in and coming out the next time.
LOL LOL
Tks for the laugh. I always thought I was the only one that had these problems.
Todd J. Kennedy
United States Navy
Ret. HOOYAH
2002 WJOE Stocker
milresq is offline   Reply With Quote Quick reply to this message
Unread 09-23-2012, 08:24 PM   #30
Siva283
Your new plugs appear to stick further into the cylinder than your old ones.
Sent from my EVO 4G using JeepForum
[QUOTE=Magnum;14117863] I gave the Jeep the required offering of $$, sweat, and blood, and everything works fine now. -- Jim[/QUOTE]
[QUOTE=ldso;16498409]. It started with a $200 axle, and a few thousand dollars later I was done :)[/QUOTE]
[QUOTE=Luuca;16122017]diagnose the real issue before you start going all Obama on it - spending mad cash you'll need for other important things.
Ask me how I know...[/QUOTE]
[QUOTE=Overhead;17658665]this is also my second set of RC springs this year. I'd rather spend the money again and get something that will last.[/QUOTE]
Siva283 is offline   Reply With Quote Quick reply to this message
