Tried to do Spark Plugs today in the 4.7--Didn't happend - JeepForum.com
post #1 of 44 Old 06-12-2004, 01:38 PM Thread Starter
Astorm
Angry Tried to do Spark Plugs today in the 4.7--Didn't happend
After reading up on it, looking on WJjeeps.com, and buying the plugs, started to do the job today. I took the intake off, etc... Unbolted one of the coils, took off the harness, and the damn thing wouldn't come off!!! I tried another one, and they are all the same, I pulled, jiggled, twisted (which is very limited by the stud, yet to no avail. None of the coils will come off!!!
This is probably one of the most frustrating things since I can't even do spark plugs anymore. I don't want to bring it to the dealer, but I do have a coupon for $62.95 for plug replacement.
I'd rather do this job myself, as opposed to someone else doing it.
Does anyone have any ideas how to get the coils off (without breaking them)?
Thanks,
Andy
2000 JGC Limited 4.7
Quadra-Drive
Addco
Flowmaster 50-Series
K&N FIPK/RamIt
Every Option
Astorm is offline
post #2 of 44 Old 06-12-2004, 02:34 PM
10achik
I ate what?
10achik's Avatar
Take the bolts off and pull like hell
seriously, you have to press down slightly and turn to unseat...then pull really really hard straight up!
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline
post #3 of 44 Old 06-13-2004, 11:50 AM
ethan1321
I just did the plugs in my wife's jeep and ran into the same problem. I just took a flat bladed screw driver and placed it between the coil mounting flange and the bottom nut of the stud then just twisted the screw driver. They all popped of like a charm then, this is after I spent about 2 hours just working on the first two. Good luck.
Ethan
ethan1321 is offline
post #4 of 44 Old 06-13-2004, 01:17 PM
10achik
I ate what?
10achik's Avatar
Come to think about it I did the same thing with a pry bar, they will come out, it just takes some force.
Ken
2006 Pontiac G6 GTP
10achik is offline
post #5 of 44 Old 08-14-2012, 09:46 PM
archinate82
Try a shot of PB or something like that before you take out the old plugs.
Then make sure you put a thin coat of anti-seize on the new plugs and lube the coils with some dielectric grease.
Did mine about 30k ago, so it's time to do them again I think.
archinate82 is offline
post #6 of 44 Old 08-14-2012, 10:02 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Do this, but be very sparing with the penetrating oil. You don't want a ton of oil draining down into the cyl when you pull the plug out.
Putting dielectric grease on the coil boots will help keep them from sticking to the plugs for future changes.
Although.... that $63 coupon sounds pretty good when you consider the giant PITA that cyl #8 is.
~Richard
billzcat1 is offline
post #7 of 44 Old 08-14-2012, 10:38 PM
Gunrunner23
Mine actually wasn't too bad. Thank god. That's a good deal considering it takes awhile to do all 8! Now do a 6cyl on a xterra.... that 6th one is the worst. 2 extension and 2 swivels.....
2004 wj limited 4.7
IRO 3in lift with skyjacker hydro
265/75/16 TreadWright Claws
Gunrunner23 is offline
post #8 of 44 Old 08-14-2012, 11:53 PM
cadga1390
now try an LS1 in a 2002 Trans AM WS6! talk about working in tough conditions. especially with factory plugs at 145k miles (owner must've lost his mind) those wires were glued on at that point. once u reach that point you've mastered spark plugs imo lmao.
cadga1390 is offline
post #9 of 44 Old 08-15-2012, 05:20 AM
2001WJv8
2015 WK
i've done my own at 30 and 60 ... but if the dealer will do it at 90 for $63 i'll go that route
'15 WK2 Diesel 4x4 ORII, Nitto TG2 275/65r18, BORA 1"f/1.25"r spacers, RRO super sliders
2001WJv8 is offline
post #10 of 44 Old 08-15-2012, 05:21 AM
shepd
If the $63 includes the plugs themselves, get the dealer to do it. At least up here, that would just barely buy you the plugs and nothing else.
shepd is offline
post #11 of 44 Old 08-15-2012, 08:10 AM
Gunrunner23
Really? 4.7 calls for copper. So like 16 bucks for all 8....
2004 wj limited 4.7
post #12 of 44 Old 08-15-2012, 08:32 AM
ZeJokee
Had the same problem. I attempted to do them but those freakin coil packs would not come off. I ended up putting it off for a few more months. Finally sprayed some PB blaster around them and pulled like hell. Once they were lubed up they came out pretty easy. Make sure, like billzcat said, put some electric grease on the orings of the coil packs so they shouldn't stick next go around.
99 WJ Ltd, Blacked out, 4.7L, 242j Swap, 2'' BB, 245/75/16 Kuhmo Venture AT KL78, Flow Master Super 40, MagnaFlow high flow Cat, Akebono caliper upgrade, Addco rear swaybar, Westin brush guard, Moog Super Trail Boss, Rancho RS5000, Rola roof rack with dual kayak J hooks, PAC-AOEM-CHR, Sony Xplod 1200w amp, 2 Sony Xplod 12'' subs, 118,XXX miles (SOLD)
93 ZJ Ltd, Blacked out, 5.2L, Reman 46RH, Reman 242 Swap, 3.5'' IRO + 2" BB, 33x12.50r15 Mud Claw MTX radials, Bushwacker Flares, 216,XXX miles (Still parked in NC)
04 F-350 SD Crew Cab FX4 Lariat, 6.0 PSD SRW, Head studs, AFE Stage 2 SI Pro Guard 7 intake, Blue Spring mod, 150,XXX Miles
ZeJokee is offline
post #13 of 44 Old 08-15-2012, 01:37 PM
cuttysark
yeah up here in canada theyre like 5.50 a piece plus tax for plugs alone. #8 is a ***** too
cuttysark is offline
post #14 of 44 Old 08-15-2012, 03:31 PM
V8 Grand
2003 WJ
I know exactly what you mean. I have a '00 Camaro SS. #8 had to be done from below. The 4.7 is EASY in comparison. Even #8 in the 4.7 isn't bad if you get the throttle and cruise control cables and the wiring harness out of the way. It takes a few more minutes to disconnect that stuff, but I think it's worth it.
V8 Grand is offline
post #15 of 44 Old 08-15-2012, 03:37 PM
2001WJv8
2015 WK
i change #8 by reaching through the flipper glass, much easier once i figured that trick out
2001WJv8 is offline
spark @ coil, no spark @ plugs 94GC52 ZJ Grand Cherokee Forum 4 07-09-2009 07:17 PM
spark plugs grandman17 ZJ Grand Cherokee Forum 10 11-25-2005 07:06 PM
Spark Plugs michiganmaveric ZJ Grand Cherokee Forum 12 11-22-2005 10:25 AM
spark plugs Derek33 ZJ Grand Cherokee Forum 7 03-10-2005 12:06 PM
Spark Plugs baseball_coach WJ Grand Cherokee Forum 1 12-15-2003 08:28 AM
