transmission shifting at 4000 rpm - JeepForum.com
post #1 of 2 Old 08-06-2011, 09:45 PM Thread Starter
sam12345
Wj transmission shifting at 4000 rpm
i have a 2001 jeep grand cherokee laredo, car starts fine and run up to 30 mph, then it wont shift into next gear unit 4000 rpm, car run fine until i get below 30 mph then it hapens again, once it kick in there no problem, i m not hearing any noise from transmission. turned ignition key 3 times gave me one fault code p1762. i brang it to the dealer they told me i need a new valve body, they didnt drop the pan, they just hooked up the scan tool, they told me they got a bunch of faults that the valve body was bad, i had this problem before and had taken it to another jeep dealer 4 years ago, they changed governer solenoid and problem was solved. do you think they were trying to rip me off, they kept telling me that i was going to get stuck on the road, i just got a bad feeling so i left and going to take to an aamco shop for a diagnostics. can someone give some advice on what this problem could be. thank you.
sam12345 is offline
post #2 of 2 Old 08-07-2011, 11:42 AM
fireman33
2003 WJ
It sounds like the pressure sensor. Thats what that code means, and also your symptoms are leading to the sensor and solenoid acting up. Check your fluid level first and make sure it doesnt smell like burnt oil. If thats fine i would go ahead and change the solenoid and the sensor.
98% of Canadian say '' oh **** '' before taking the ditch in winter time. The other 2% are from New-Brunswick and say '' hold my beer and watch this ''
2003 WJ 4.0, 4'' IRO Critical Path, 31x10.5x15 goodyear wrangler territory on soft 8's, Tom Wood front drive shaft, Rough country SS, 4.56 G2 gears, D30 front, D35 rear/detroit trutrac, IRO adj. trackbar, Doetch tech 8000 shocks, nv242 TC, midland cb, 3' firefly antenna, Mopar TC Skid
My build thread-->
fireman33 is offline
Help with Up-Shifting and Down-Shifting problem? jvill030 WJ Grand Cherokee Forum 0 05-25-2011 09:57 PM
$4000 for a Rear Diff? cultcab WJ Grand Cherokee Forum 58 03-26-2011 03:50 PM
MoneyPit WJ needs help - Transmission clicking when shifting from Park to R or D bradn WJ Grand Cherokee Forum 12 02-23-2011 06:02 AM
Please help transmission problem not shifting 99jgcl WJ Grand Cherokee Forum 5 01-22-2011 07:40 PM
Creaking Noise when Shifting Automatic Transmission rspina WJ Grand Cherokee Forum 20 08-05-2010 02:21 PM
