Transmission issues after stroker build - JeepForum.com
post #1 of 12 Old 06-18-2013, 08:42 PM Thread Starter
scross1220
2012 WK
I have a 2002 JGC 4.0l that I strokered to 4.6l. After the build and testing during engine breakin I noticed that when driving the when the trasmission is shifting from 3rd to 4th that the shifting is not always smooth and sometimes shifts quikly with at little reving. This is more aparent when I and driving and let off the gas during the time the transission shifts from 3rd to 4th gear. I did not have this befor I strokered it but not it happens a lot. There is no jerking but the best way to describe it is like it misses the shift. What am I dealing with?
______ooooo
/__l_l_,\____\,___
l_---l_l__l---[o]llllll[o]
_.(o)_)__(o)_)--o-)_)
If you're not fixing it, you're not driving a Jeep.
scross1220 is offline
post #2 of 12 Old 06-18-2013, 09:15 PM
Terminal
Sounds like you're dealing with a junky 42re tranny that barely held up to the stock 4.0 power to begin with
Terminal is offline
post #3 of 12 Old 06-18-2013, 09:29 PM
chrism1367
2003 WJ
Mine does the same thing on the 3-4 shift, doesnt take long to shift but a little harder than other gears, it is not a smooth shift. I'm guessing clutch pack or something worn. Was like that when I bought it. After doing complete filter and fluid change it got a little smoother. Hasn't gotten any worse though since I've had it which is good.
chrism1367 is offline
post #4 of 12 Old 06-18-2013, 09:41 PM Thread Starter
scross1220
2012 WK
Ah crap sound like mine. I didn't have the issue till the the stroker build but I beginning to think the new engine may be too much for it. Did a fluid change 8k ago but the filter has not been changed. Are there any adjustments Like the shift bands that could help?
______ooooo
/__l_l_,\____\,___
post #5 of 12 Old 06-18-2013, 09:55 PM Thread Starter
scross1220
2012 WK
Its definately a slip now that I have read some threads. I have to listen to see if its slipping from 2nd to 3rd or 3rd to 4th.
______ooooo
/__l_l_,\____\,___
post #6 of 12 Old 06-19-2013, 09:35 AM
Cebby
I think there is some band adjusting you can do to it with a filter/fluid R&R. I've yet to crack into my tranny - scared of it...
2000 WJ Laredo 4.0 4x4 Taupe Frost - Stroker | Clayton LA w/3" Lift | 33's on JK 17's | Axles next
Cebby is offline
post #7 of 12 Old 06-19-2013, 10:10 AM
chrism1367
2003 WJ
I think there is some adjustment you can do but I'm afraid of turning my trans into a big paperweight
post #8 of 12 Old 06-19-2013, 10:35 AM
the88thpianoman
2003 WJ
Before you get into that hairy process, try adjusting the throttle kickdown cable. It's the only adjustable cable of the three connected to the throttle body. Try pulling that out a couple notches at a time to increase line pressure inside the transmission and get firmer, quicker shifts. That's also much better for your transmission because the clutches spend less time slipping, so they wear less. The only reason it shifts soft from the factory is that most consumers prefer a gentle, comfortable shift.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #9 of 12 Old 06-19-2013, 01:04 PM Thread Starter
scross1220
2012 WK
That was it. I adjusted the throttle kickdown cable 5 clicks and I was fine. There was too much slack in the cable. Thanks for your help.
______ooooo
/__l_l_,\____\,___
post #10 of 12 Old 06-19-2013, 01:19 PM
chrism1367
2003 WJ
I def have to try that. Simple as it sounds I hope
post #11 of 12 Old 06-19-2013, 03:52 PM Thread Starter
scross1220
2012 WK
Thank you again Jonathan for that tip it worked like a charm.
______ooooo
/__l_l_,\____\,___
post #12 of 12 Old 06-20-2013, 01:29 PM Thread Starter
scross1220
2012 WK
I have a question for you all. When I was having the issue with my transmission not shifting correctly I made a call to AAMCO and asked if they could adjust the bands in my tranny. The machinic said to me that there were no adjustments on my transmission and that they were auto adjusting. I am not an expert but I know that it was a lot of bull. The problem ended up being a TV kickdown cable adjustment as mentioned by jonathan but what I like to know is why the machanic told me there was not band adjustments on transmission? Any thoughts?
______ooooo
/__l_l_,\____\,___
