Transmission delay in moving - JeepForum.com
post #1 of 3 Old 07-17-2013, 03:55 PM Thread Starter
rdkendrick
2003 WJ
I cannot remember where I read about the fix for a transmission. Some times when I put my '03 Jeep GC Overland into drive, it starts to move slowly, then when I hit the gas, it moves normally. If I rev it up before putting it into gear, it is OK. I recently read (I could have sworn it was a TSB) where the torque converter is not primed and filled up with fluid and the fix wax to replace one of the filters and something else, but I cannot remember.
I went over the TSB's at wjjeeps.com, but cannot find it, unless I am just not seeing it. Has anyone else seen this?
Sent from my iPad using Forum Runner
rdkendrick is offline
post #2 of 3 Old 07-17-2013, 05:43 PM Thread Starter
rdkendrick
2003 WJ
Never mind, I must be blind. I found it. Good thing I printed it out last night. It is TSB 21-015-05
45RFE/545RFE Trans-Delayed Engagement Due to Cooler Return Filter Replacement.
post #3 of 3 Old 07-19-2013, 02:56 AM
cykaaro
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
