Transmission buzz - JeepForum.com
post #1 of 5 Old 03-13-2014, 09:53 PM Thread Starter
03CUSEWJ
2003 WJ
Talking Transmission buzz
Since I have had this Jeep I have had the buzzing sound coming from the transmission when cold, in reverse. From what I have read on here it is "normal". I have the 42re in this WJ, but I have had these transmissions in other chrysler vehicles that have not made this buzzing sound. I found this TSB on the WJ site and I am wondering if anyone has performed the repair. I am planning on doing a shift kit with my next fluid change and figured what the heck I might as well get rid of that annoying sound. Any words of wisdom from those with experience with it? thanks!
http://www.wjjeeps.com/tsb/tsb_wj_210899.pdf
03CUSEWJ is offline
post #2 of 5 Old 03-13-2014, 11:20 PM
jra8858
Thank you for posting that link, I also have noticed a moaning sound when first put in reverse in the mornings. Only seems to do it when really cold. At first I thought it was the power steering pump, at least now I know it is a fairly common problem and not a sign reverse is about to give out.
jra8858 is offline
post #3 of 5 Old 03-13-2014, 11:50 PM
andrewx12
Make sure to use atf+4 rather than 3 if you do. If the system has 3 in it 4 will still work without any issues as it is still compatible.
Current repairs needed:
AT filter and fluid
andrewx12 is offline
post #4 of 5 Old 03-14-2014, 09:05 AM Thread Starter
03CUSEWJ
2003 WJ
Thanks with the heads up, Andrew. Hoping someone that has done this TSB will see this and chime in...
03CUSEWJ is offline
post #5 of 5 Old 03-14-2014, 02:30 PM Thread Starter
03CUSEWJ
2003 WJ
Refresh for the evening crowd......
03CUSEWJ is offline
