Transmission acting weird: Hard shifting - Page 2 - JeepForum.com
post #16 of 20 Old 12-20-2012, 02:43 AM
stricnine
1987 YJ Wrangler
ok thanks i will change it just to eliminate another possibility and the aic valve. it may end up like the others and just need extra fluid
87 yj 4.2 5 speed soa bigger spring pack and 1" shackles
35 15.50 tsl swampers 15'' mickey thompson 10" wheels
stricnine is offline
post #17 of 20 Old 02-17-2013, 09:26 PM Thread Starter
nlabs
yea the thing that sucks is idk when the last time the tranny was ever serviced, the fluid is burnt or black, so i highly doubt a service will fix it, but its worse in lower speeds
nlabs is offline
post #18 of 20 Old 06-24-2013, 08:19 AM
samiam2187
Did you ever get a resolution on this problem? I'm contemplating changing out the Transmission speed sensor as well.
samiam2187 is offline
post #19 of 20 Old 06-25-2013, 08:43 AM
stricnine
1987 YJ Wrangler
Yes 2 problems I fixed the air intake control had the spring broken. Also injector #3 had what ppl call heat soak. It seems just like tranny probs. I changed aic and took a piece of stuff called heat max 2 its for making industrial gaskets and wrapped it around the injector. Bam prob solved
post #20 of 20 Old 06-25-2013, 09:22 AM
RigoJeep
Samiam, what exactly are your tranny symptoms?
RigoJeep is offline
