Transfer Case Swap Help - JeepForum.com
post #1 of 30 Old 06-13-2012, 09:49 PM Thread Starter
D0dgeRam1500
Wj Transfer Case Swap Help
First off I have a 2004 Jeep Grand Cherokee Overland 4x4 with 96,000 miles. My NP247 died today and with the help of my club and this forum I would like to swap in a NP242HD. I have seen and read the following thread but it is confusing. http://www.jeepforum.com/forum/f310/...d-swap-510546/ I read that the NP242HD has a aluminum tail cone and that output shaft is suppose to be 32 spline. Is there another way of telling that it is the right case and drive shaft? How long is the drive shaft suppose to be? I know it's 2 inches shorter but what is the actual length? Is there a model number on the transfer case? I want to make sure I do this right.
2005 Jeep Wrangler Willys Edition
D0dgeRam1500 is offline
post #2 of 30 Old 06-13-2012, 10:29 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
The transfer case will say either 242J, 242WJ, 242bla bla J lol, it really doesn't matter. I have seen the HD's and the standard 242's with the exact same tags. Just confirm that it came out of a WJ with a 4.7. All you can really do is look at it to see the 2.25" input shaft, aluminum tail cone, and that it says 242 on it. Also, just make sure the shaft fits into the tail cone. I don't remember the length of it, but if it fits into the tail cone, its the right one. 99 times out of 100, since these things are fairly rare, the shaft will be the one they pulled from the jeep they also pulled the case from. Buy from a reputable place like LKQ and you shouldn't have a problem. They also had the lowest price (by far) when I bought mine.
~James
ezflip is offline
post #3 of 30 Old 06-14-2012, 03:34 AM Thread Starter
D0dgeRam1500
Not to be a complete noob but what is LKQ?
post #4 of 30 Old 06-14-2012, 04:51 AM
penguinland
penguinland's Avatar
http://www.lkqcorp.com/
2004 WJ 4.0
2" BDS springs + 3/4" spacers up front , Goodyear Duratrac 245/75R16, Yaesu FT-7900R
penguinland is offline
post #5 of 30 Old 06-14-2012, 01:17 PM
Indslpwr04
Well since someone already started a thread, I m looking into getting a 99 with full time tcase. I already did the swap on a ZJ with a 5.2 in it and had to split the 242 case and add the front half of the 249 case to get the output of the transmission to completely slide into the tcase. Will the same case i have swapped into the zj bolt right up to the 4.7 tranny in the WJ. I dont want to have to rip another tcase apart.
Thanks for the help. You guys walked me through the first swap and really appreciated it!!
2002 Overland. All stock, for now.
Indslpwr04 is offline
post #6 of 30 Old 06-14-2012, 03:00 PM Thread Starter
D0dgeRam1500
I called LKQ for the parts and the guy got fed up with me when I was asking questions about the parts to make sure they are the right parts and hung up on me. Some customer service...
post #7 of 30 Old 06-14-2012, 03:40 PM
skain8
skain8's Avatar
search www.car-parts.com. Depending on year, it will ask which engine and the 242 case. I would still verify the HD model from there when you call the wrecker lots.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #8 of 30 Old 06-14-2012, 03:44 PM Thread Starter
D0dgeRam1500
I'm currently talking to one of the shops from car-parts.com. They are assuring me that it is coming out of a 2002 Jeep Grand Cherokee with a 4.7L. They are taking out the rear drive shaft too. Is the 2.25" input shaft part of the transfer case? None of these places want to take a picture to prove it's the right part though.
post #9 of 30 Old 06-14-2012, 04:39 PM
skain8
skain8's Avatar
Its HD if the 242 came out of a 4.7L.
skain8 is offline
post #10 of 30 Old 06-14-2012, 07:40 PM Thread Starter
D0dgeRam1500
Can I trust them is my question though. I have no recourse if they screw me.
post #11 of 30 Old 06-14-2012, 10:44 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
They have a money back guarantee. I think it is 30 or 60 days. Maybe longer. They had everything I needed sitting up front just waiting for me to pick up. Everything was perfect. I wouldn't hesitate to order from them again, even though the closest one to me is 2.5 hours away.
~James
ezflip is offline
post #12 of 30 Old 06-15-2012, 03:34 AM Thread Starter
D0dgeRam1500
Your talking about LKQ right? Does car-parts.com do this?
post #13 of 30 Old 06-15-2012, 03:36 AM
SirWilliam
LKQ is a chain of salvage yards. car-part.com is a nationwide database of independent salvage yards that you would contact individually on your own if they have what you want. But I haven't seen any yard that will make you take something if you get there and it's not what you want. Even if they have to pull it for you, they'll just shelve it and go on. It happens every day.
2004 WJ Overland - 4.5" Lift - 2012 JK Sahara 18" 7-Spoke Polished Wheels with stock JK Bridgestones
SirWilliam is offline
post #14 of 30 Old 06-15-2012, 04:45 AM
michigan-tater
I got mine this spring off of car-parts.com I founf out the hard way that the rear drive shaft lenght is 25 inches weld to weld. (They came from diffrent places) and I asked when I got the tcase if it came from a v8. And they were find with my questions.
1996 zj 4.0
stock for now
michigan-tater is offline
post #15 of 30 Old 06-15-2012, 05:10 AM Thread Starter
D0dgeRam1500
I have to have the part shipped so I won't see it until it gets here. That's why I wanted them to take a picture so I can verify it's right.
case , jeep , swap , transfer , wj
transfer case swap q's mrJ WJ Grand Cherokee Forum 40 03-13-2012 10:03 AM
WJ transfer case swap JeepFreak1982 WJ Grand Cherokee Forum 1 02-03-2012 08:35 PM
Transfer case swap? Is it possible? bholl85 WJ Grand Cherokee Forum 17 01-16-2012 08:35 AM
Transfer case swap jared67 WJ Grand Cherokee Forum 0 09-05-2011 09:58 PM
Transfer case swap? Jeepwj00 WJ Grand Cherokee Forum 1 01-17-2011 01:41 PM
