Transfer Case Service - JeepForum.com
post #1 of 24 Old 01-05-2014, 06:45 PM Thread Starter
purplecty
2003 WJ
My 2003 4.0 WJ laredo is at 174000 miles and im only assuming I should service my transfer case since it has yet to be done. Any write up links or recommendations? Thanks in advance...
Pearl Blue WJ Laredo 4.0-(202,xxx Miles) - COMPLETELY STOCK!!!
purplecty is offline
post #2 of 24 Old 01-05-2014, 06:56 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Remove top fill hole bolt
Remove bottom drain hole bolt
When fluid is done draining, replace bottom drain hole bolt.
Fill with proper fluid. ATF 4 for the select track or dealer only 247 fluid for Quadra drive or track.
Replace top fill hole bolt.
Profit???
Sent from inside my dinosoar head.
~James
ezflip is online now
post #3 of 24 Old 01-05-2014, 07:01 PM Thread Starter
purplecty
2003 WJ
Profit???
Thanks! What do you mean by profit?
post #4 of 24 Old 01-05-2014, 07:12 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
It's an old internet meme lol. Don't worry about it.
~James
post #5 of 24 Old 01-05-2014, 07:19 PM Thread Starter
purplecty
2003 WJ
Oh haha ok cool thanks again! Any specific brand atf +4?
post #6 of 24 Old 01-05-2014, 07:35 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
The cheapest stuff you can find. ATF 4 is ATF 4.
~James
post #7 of 24 Old 01-05-2014, 07:38 PM
KonLegend
2005 WK
I must use the dealer only fluid for my Quadra Trac II, but for yours if it specifies atf 4, I would use atf+4 synthetic. Any brand should do, it is a spec to meet
2005 WK 5.7 Hemi Limited
Superchip Performance Tune
K&N Intake
Flowmaster Super 40 w/reso delete
KonLegend is offline
post #8 of 24 Old 01-05-2014, 08:07 PM
Punisher8738
Buy the 247 fluid online...way cheaper.. That is if you need it.
I ordered it off eBay for 10.00/quart. Just for shuts and giggles I asked the local dealership... They wanted almost $30/quart and quoted me $165 to service just my 247 transfer case... Differentials quoted at $185/each... Rediculous rates
Punisher8738 is offline
post #9 of 24 Old 01-07-2014, 04:53 AM Thread Starter
purplecty
2003 WJ
I have select trac...
post #10 of 24 Old 01-07-2014, 07:31 AM
dcorn
Might as well get some decent ATF since you don't have to replace it very often. Plus its only 2 quarts.
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #11 of 24 Old 01-07-2014, 07:39 AM Thread Starter
purplecty
2003 WJ
What do you recommend?
post #12 of 24 Old 01-07-2014, 08:02 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
ATF 4 is the spec for the fluid, not the general name of it. If it says ATF 4 on the bottle, it is exactly the same whether the bottle costs $2 or $17. Just go to Wal-Mart and pick up the cheappest bottle they have.
~James
post #13 of 24 Old 01-07-2014, 08:12 AM Thread Starter
purplecty
2003 WJ
Ok
post #14 of 24 Old 01-07-2014, 08:47 AM
Cirruslydakota
All atf+4 is synthetic and its the same formula. If it meets the type 7176 spec then go with it. Walmart sells it under its supertech brand and it works just fine.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
post #15 of 24 Old 01-07-2014, 08:49 AM Thread Starter
purplecty
2003 WJ
Awesome! Thanks for the info...
