transfer case output seal replacement procedure, am i messing anything ? - JeepForum.com
post #1 of 15 Old 06-22-2010, 02:18 AM Thread Starter
straty1987
I have to replace the output seal on my 247 transfer case and want to make sure i do it right the first time.
most people recommend the mopar seals over others and other parts stores have them listed odd or wrong. i believe the mopar part number is 4897298AA for the 247 SEAL OUTPUT SHAFT.
i have gathered this is the correct way to do it. correct me if i am wrong
1) drive the rear of jeep up on a ramp and chock the front tiers
2) put on the parking break on, because I will have to remove the rear drive shaft and "park" does not work when the drive shaft is disconnected.
3) Drain transfer case fluid
4) mark the line across the pinion yoke so it will be installed right later, then Remove rear drive shaft and slide it out of the t-case output. oil might leak out so keep a oil pan near by and keep the TC output shaft for getting dirty or damaged.
5) The old seal is now exposed. Hook it with a "seal puller" tool and pry it out of there. Careful you are prying on the seal and not digging into the aluminum inside the housing. It should come out somewhat easily.
6) Tap the new seal in place. You can do this easily with just a rubber mallet and block of wood
7) Re-install drive shaft. Careful there is no dirt on the surface that is to seal with the t-case.
8) fill the TC with new fresh fluid
question
-how heavy will the drive shaft be?
since i will be on my back, should i consider putting a jack stand under it just for help?
- will these work for step 5?
AutoZone.com | 5 lbs. Slide Hammer | 5 lbs. Slide Hammer and
AutoZone.com | 4 wheel drive spindle puller attachment for use with OEM slide hammer 27033 and others with 5/8 in. x 18 thread | 4 wheel drive spindle puller attachment for use with OEM slide hammer 27033 and others with 5/8 in. x 18 thread
- if not anyone have another method for removing the seal?
like with a screwdriver or pliers
- in step 6 when using a block of wood, the wood has to be thin enough to go into the output shaft correct?
- when installing the shaft going into the TC can it go in wrong or is there no wrong way?
i know when connecting DS to the rear it has to be installed in the same way i removed it.
- this should be an hour job max right
thanks for your time and have a few pics below
also so i looked in the FSM
and these is the how to for removing the drive shaft, this is simple
and this is the how to for the seal the special tools are throwing me off
what my TC looks like has been leaking more but not to a puddle amount, and just want to fix it
straty1987 is offline
post #2 of 15 Old 06-22-2010, 02:06 PM Thread Starter
straty1987
bumping it back to page 1, thanks
post #3 of 15 Old 06-23-2010, 03:48 PM Thread Starter
straty1987
just going to go a head and do it and if i run into anything problems will try to figuer it out myself or post a new thread.
figures someone would have some info on this since people say the seals breaking are common thing.
post #4 of 15 Old 06-24-2010, 10:29 AM
SA59GRAND
straty1987....Let me know how it goes, I hope it is the same method to replace the Transmission Output Seal because mine is Leaking Output Seal on back of Transmission leaking on my ZJ on Flickr - Photo Sharing! If I can find any Info I will send it to you.
SA59GRAND is offline
post #5 of 15 Old 07-04-2010, 02:43 AM
nazerine
Sorry to bump this a little late, but I did the rear output/tcase input shaft seal on my 44re/242. Also did all 3 seals on the tcase...
Buy one of these tools, cheap, and makes removing seals of this type (with a shaft in the way), really easy. Just be careful with the sharp claw
Lisle Corporation
'96 ZJ Limited 5.2L
nazerine is offline
post #6 of 15 Old 01-03-2011, 05:24 PM
mcclintock89
looks like i'll be doing this one this weekend. how did replacing the seal go?
mcclintock89 is offline
post #7 of 15 Old 01-03-2011, 06:55 PM
nickblack
The special tools shown in the FSM are to remove the bushing behind the seal, which is unecessary. Just change the seal as you described.
nickblack is offline
post #8 of 15 Old 01-03-2011, 07:04 PM
nickblack
Straty, re read ur post. DO NOT put wood into out put seal. Place seal in opening and using a mallet, place block of wood over the seal and tap it in until seal is flush with opening. You can remove the seal with a $5 seal puller or a vise grip. If you have a slide hammer u can use that too, but I wouldnt buy it unless u are building ur tool box. A cheap set of bearing race drivers are also good to tap seals in. I think Lisle tools has a set for $15 or so. Also, driveshaft is surprisingly light, U don't need a jack to support it.
post #9 of 15 Old 01-03-2011, 07:54 PM Thread Starter
straty1987
never had the time to do it since i tried to take off the bolt on the yoke and did not move so i hit it with more PB blast and liquid wrench never had time, but been toping off my fluid.
i did notices that to take off the bolt a opned end wrench and a cheater bar will help, but the bolt is so small that teh wrench is really thin and might bend. forgot teh size think its 8mm
might want to look into the vent house being clogged, happens to a few people. its at the top of the TC
post #10 of 15 Old 01-03-2011, 07:57 PM Thread Starter
straty1987
i realized now that putting the wood in the TC make no sens now and that the DS are light(nerve held one before) lol and i bought a seal puller from autozoen since it was cheap and have to do a pinion seal in my front diff aswell, adding tools to my set, which is good and bad
you would not have any advice on the steps for a pinon seal on a dana 30?
i keep thinking i can do it but don't want to mess up the gears and kill my diffs. just don't have any local diff shop around me and don't trust the small shops since they will not back there work, if the diff goes bad they cant covering anything. so just been topping it off since i noticed the leak.
post #11 of 15 Old 01-03-2011, 09:55 PM
nickblack
If you have the tools and the FSM it is pretty straight forward. I rebuilt my Dana 30 diff last winter. You will need an inch/pound torque wrench. Something to hold the yoke when u tighten the pinion nut and a slide hammer makes it real easy to pull the seal out. When reassembling, I highly recommend using the new type of pinion nut that was issued by Jeep that has a flanged nut rather than a nut washer combo. This is addressed, with part #'s in TSB 030899. My old style nut backed off and ruined my diff, had to rebuild. if you choose not to order new style nut at least buy a new nut and washer. That "torque to turn pinion" measurement is crucial, don't mess that up or will get an axle whine and potential problems with diff if not accurate. Sounds like a lot but really not that bad. just go slow, follow manual EXACTLY and use the right tools. Also, not the most pleasant job to do without a lift, but doable. Ask more questions if needed.
post #12 of 15 Old 01-03-2011, 09:58 PM
nickblack
also, coat the outside of the new pinion seal with RTV silicone for added protction before installing.
post #13 of 15 Old 12-09-2014, 07:06 PM
volvite
Thread revival!!!
I have a 99 WJ with the 4.7L V8 and the 247 transfer case. Both output shaft seals have been leaking slowly so I've decided to change the seals. The rear driveshaft and rear seal went smoothly. However, I'm now stuck on the front. I've removed the front driveshaft but I can't seem to get the old seal out. I've bought two different seal pullers, the hook and what's called Lisle shaft type puller. Still no luck. Is there something I'm missing? I can't drive or put fluid in the transfer case as the seal is all jacked up. Any input you all have would be great. I need to get my jeep up and driving again.
His 99 WJ Limited 4.7
Hers 15 Overland EcoDiesel, ORAII
volvite is offline
post #14 of 15 Old 12-09-2014, 10:01 PM
Jeepwalker1
1987 XJ Cherokee
Usually there is a lip on those isn't there that you can get under with a gasket scraper and tap the seal out with a hammer. Should come out, keep trying.
I always use Mopar seals. They have an extra lip that the aftermarket seals don't usually have.
When you go to put the yoke back on, put a dab of silicone sealer under the nut so no fluid will leak past the yoke splines. Make sure both the splines and inside yoke are clean and not oily.
'87 XJ Snow Plow Truck, '95 ZJ, '03 WJ Overland, '98 Land Rover Discovery
Jeepwalker1 is offline
post #15 of 15 Old 12-09-2014, 10:22 PM
volvite
Thanks for the post. I've owned the Jeep since about 40K miles. It now has 120K and I think this is the first time the transfer case seal has been replaced. Never had an issue until recently. I'm assuming it's the original OEM seal and I purchased a mopar seal to replace it with. Just need to pull it out somehow.
volvite is offline
Tranny output/Tcase input seal replacement, seals look fine? snakester14 ZJ Grand Cherokee Forum 4 06-14-2010 04:23 PM
Transmission output seal + Transfer case. Windowsrookie ZJ Grand Cherokee Forum 8 10-10-2009 01:58 AM
247 transfer case output shaft seal r&r- need tips Black994x4 ZJ Grand Cherokee Forum 1 01-01-2009 02:09 PM
42RE Output shaft seal replacement UltimatE ZJ Grand Cherokee Forum 5 10-16-2007 09:44 PM
Output shaft seal replacement? EnolaEngineerGC ZJ Grand Cherokee Forum 6 11-28-2006 09:11 AM
