transfer case/front axle/driveshaft ques. - JeepForum.com
post #1 of 7 Old 09-18-2017, 06:04 PM Thread Starter
jp1969
Been getting a hum/whirring noise during acceleration that changes pitch as I crest a hill or go over a dip. Can also feel a slight vibration in the floor. No noise when coasting or during deceleration. Checked both differentials. The back fluid looks good. The front is a milky gray (just changed fluid in both a few months ago). Led me to assume front axle issues(pinion bearing?) so I was all set to replace the front axle with one from a yard (led to help post last week). Buddy that is helping suggested that it might not be the front axle after all. Three questions:
1. Anyone have similar problems that can shed some light?
2. Do these sound like symptoms of front axle issues?
3. Is it OK to disconnect the front drive shaft(247 Transfer case) and run it to isolate the front axle?
Again any help would be greatly appreciated!
jp1969 is offline
post #2 of 7 Old 09-18-2017, 07:15 PM Thread Starter
jp1969
Been looking through old threads. Seems like it's OK to run without front drive shaft, but now have more questions. Pretty sure I have a quadra-trac 2. I've already picked up a used axle. Are the front axles from Quadra trac 2 and Quadradrive interchangeable? If not, how do you tell the difference?
jp1969 is offline
post #3 of 7 Old 09-18-2017, 10:27 PM
Topher11
Topher11's Avatar
QD axles are limited slip. No issue interchanging them, and having the LSD is much better than an open diff. So it's a win win.
The vibes on the other hand sound more like your drive shaft anges are bad or if u have rzeppa joints they could be shot.
Drop the front shaft and run it down the road and see what changes. In the end you may as well put that QD axle in if you've already got it.
1999 WJ 4.0/6"/CLAs/33s/242SYE/ZJ Rad Swap
2006 LJ 4.0/2.5"/33s
Respected Access Is Open Access. Tread Lightly.
Topher11 is offline
post #4 of 7 Old 09-19-2017, 04:18 PM Thread Starter
jp1969
Thanks Topher11! Not sure how drive shaft angles could have changed as haven't done any work or off-roading. Have the cv style joint @ the transfer case, so maybe that's the place to start once I'm sure the noise is coming from the front end. Don't know which front axle I got from the yard, only that it was a Dana 30/355/front u. Maybe got lucky and have the better one! Will post when I get this resolved.
jp1969 is offline
post #5 of 7 Old 09-23-2017, 06:27 PM Thread Starter
jp1969
Topher11 called it and saved me a great deal of work! dropped the front shaft and the joint @ the TC was toast. Was able to fix with a repair kit from NAPA for $160. Guess I have a spare front axle with all the components when needed. Thanks Topher11!
jp1969 is offline
post #6 of 7 Old 09-23-2017, 06:46 PM
usserya
1977 CJ7
Mine does not have a front drive shaft and drives around town just fine.
usserya is offline
post #7 of 7 Old 09-23-2017, 08:11 PM Thread Starter
jp1969
Daughter's 1st car. 4WD in northeast NY is a BIG plus. Peace of mind well worth the cost and effort.
jp1969 is offline
