Transfer Case Fluid? - JeepForum.com
post #1 of 18 Old 06-08-2013, 09:29 AM Thread Starter
GrandGuy
Question Transfer Case Fluid?
What kind of transfer case fluid should I put in my 2002 Jeep WJ. I've seen people use both ATF+4 and NV247. It's and automatic V8 by the way.
Thanks
<> 02 WJ <> 4.7L V8 <> Skyjacker H7016 Hydro Shock W/Red Boot <> Original Rims - Plasti-Dipped <> Cladding's Plasti-Dipped <> Ionic Predator Push Bar <> Fogged Tail Lights <> BF Goodrich Tires <> You know you drive a WJ when you see another lifted WJ and wonder if he's on the forum. <>
GrandGuy is offline
post #2 of 18 Old 06-08-2013, 09:34 AM
Red350ss
It depends on which transfer case you have.....easy way to check is look at the bezel behind your shifter and see what it says....Quadra-drive and Quadra-trac take the NV247 fluid, Selectrac takes ATF4
Barron
2004 WJ Overland
Red350ss is offline
post #3 of 18 Old 06-08-2013, 09:38 AM Thread Starter
GrandGuy
I believe i have a Selec-Trac. Can this also take NV242 or just ATF+4?
Based on: http://www.wjjeeps.com/tcases.htm
GrandGuy is offline
post #4 of 18 Old 06-08-2013, 09:47 AM
Terminal
NV247 uses special Mopar gear oil only. I just flushed mine a couple of weeks ago. 2 quarts ran $30 bucks from the stealership. I'm pretty sure the NV242 uses ATF though.
Terminal is offline
post #5 of 18 Old 06-08-2013, 09:56 AM Thread Starter
GrandGuy
How many do you believe I should buy? I think most people get 2 quarts.
GrandGuy is offline
post #6 of 18 Old 06-08-2013, 09:58 AM
Terminal
Two quarts is all I bought. Verify on the transfer case unit itself whether it is a 242 or 247.
Terminal is offline
post #7 of 18 Old 06-08-2013, 03:07 PM
OffroadOran
I can confirm the nv242 uses atf+4 as i just did it less than a month ago with better shifting response and no issues. I used valvoline atf+4 full syn but any atf+4 will work
04 Steel Blue Pearl laredo WJ 4.0L, NV242 TC, 42RE Trans, Dana 30 & 35C, 3.55 gears: 99% stock.
OffroadOran is offline
post #8 of 18 Old 06-08-2013, 03:19 PM
lazyWJ
2006 XK Commander
2 quarts if fine for the 247 for a drain and refill. The factory fill was ATF 4 until mid 99 so you can use it in a pinch, but really should have the dealer only stuff. ATF was found to cause chatter/binding. Mobil 424 is a suitable alternate, and some other hydraulic oils will work but you'll have to do your homework. For the cost of the proper stuff it's not really worth futzing around with alternates unless you can find the 424 somewhere in quarts; you could save a couple dollars. I can get it around here, but it's in a 20L pail... a lifetime supply.
2004 Imola BMW ZHP
2006 Commander Limited Hemi QD2
"Bought, Not Built"
lazyWJ is offline
post #9 of 18 Old 06-09-2013, 03:35 PM Thread Starter
GrandGuy
I believe mine uses NV-242 not NV-247 though. I can't seem to find any NV-242 anywhere online. Is it possible for me to use NV-247 on a Selec-Trac?
Or should I go with an ATF+4?
eBay link: http://www.ebay.com/itm/CHRYSLER-DOD...e67a50&vxp=mtr
Info based on: http://www.wjjeeps.com/tcases.htm#QUADII
I have a 2002 WJ Laredo V8
GrandGuy is offline
post #10 of 18 Old 06-09-2013, 03:36 PM Thread Starter
GrandGuy
I have a 2002 WJ Laredo V8 Auto
GrandGuy is offline
post #11 of 18 Old 06-09-2013, 03:42 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
The select trac transfer case (242 is the model number) uses plain old ATF+4.
The Quadra-xx transfer case (247 model number) uses the 247 specific fluid from the dealership.
~James
ezflip is offline
post #12 of 18 Old 06-09-2013, 06:40 PM Thread Starter
GrandGuy
Can I use ATF+4 for a transfer case though? Isn't ATF+4 transmission fluid, or is it the same thing?
Would you mind giving a link to something I could use if possible.
GrandGuy is offline
post #13 of 18 Old 06-09-2013, 06:50 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Yes, that is what I and everyone else in this thread has said.
And ATF+4 is ATF+4. It doesn't matter at all what brand you use, its all the same. Just go to walmart or any auto parts store and grab the cheapest bottle that says ATF+4.
~James
ezflip is offline
post #14 of 18 Old 06-09-2013, 06:51 PM
wj4play
Yes and yes - ATF+3 is what the manual calls for but +4 replaced 3
I used Lucas oil in mine 195k and no problems
Sent from iPhone
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline
post #15 of 18 Old 06-09-2013, 06:56 PM Thread Starter
GrandGuy
Thanks guys sorry for being a pest
GrandGuy is offline
