Transfer Case Filler Plug - Page 2 - JeepForum.com
post #16 of 21 Old 05-01-2013, 08:27 PM
Krom
Originally Posted by js12278 View Post
IMO, those do not look like hairline cracks. They appear to be casting marks.
X2
I looked closely at the pic, and a good allen socket should work just fine on that, after you tap in into the plug with a hammer until it bottoms out. Looks like the wrench wasn't all the way in, and you only stripped the outer half or so
Krom is offline
post #17 of 21 Old 05-01-2013, 08:37 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Any machine shop should be able to get that out for less than $30. Maybe a couple bucks more since theyll have to do it on their back, but its a super easy, 30 second job for a shop that knows what they are doing.
~James
ezflip is offline
post #18 of 21 Old 05-01-2013, 09:53 PM
Jeeples
Jeeples's Avatar
Had the same problem when I changed the fluid on my wife's WJ. Here's what I did:
Get a drill bit that fits in the center of the rounded out plug (3/8 IIRC), coat it in grease the drill the center out. The grease will help prevent metal shavings from falling into the t-case.
Took the largest easy out that I could fit and removed it using an open ended wrench.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #19 of 21 Old 05-01-2013, 10:30 PM
perfeng702
try a punch and a hammer. or use a dremel to slot it and tap with a flathead.
1999 WJ 4.7, 242HD, IRO 4" Long Arm, IRO Adj Track Bar, JKS BPE, JKS Quick Disco, 15" Cragar D-Window, 32" BFG KM2, V3 Projectors, DDM Tuning 55w 5k HIDs
perfeng702 is offline
post #20 of 21 Old 05-03-2013, 10:01 PM Thread Starter
as350b3e
I found someone who is a very competent mechanic (Helicopter and heavy equipment mechanic) that will weld a 10mm allen driver onto the plug.
Got a new plug today and problem is most likely going to be solved.
Thanks all for info.
Enjoy the weekend!
as350b3e is offline
post #21 of 21 Old 05-03-2013, 11:32 PM
PhantomWJ
2003 WJ
Enjoy the weekend!
I cut a bolt..welded it an now use a socket to remove said bolt/plug
PhantomWJ is offline
