Transfer Case Filler Plug - JeepForum.com
post #1 of 21 Old 05-01-2013, 04:01 PM Thread Starter
as350b3e
The plugs allen is worn out and I can not remove the filler plug......What can be done?
How difficult is it to remove the Transfer Case and replace the cover with a new one? Is it even possible to remove the cover without removing the transfer case?
How about those hairline cracks, no leaks yet but are these common?
as350b3e is offline
post #2 of 21 Old 05-01-2013, 04:05 PM
Upside
There is a thread online about disassembling a 242 in the vehicle. Not sure I'd want to do it that way but it's possible. I can't see your pic, is the plug stripped?
Upside is offline
post #3 of 21 Old 05-01-2013, 04:12 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Hammer the next size larger Torx or triple-square socket into it. Heat up the surrounding case area with a torque and remove the plug. Replace the plug with a new one.
~Richard
billzcat1 is offline
post #4 of 21 Old 05-01-2013, 04:18 PM Thread Starter
as350b3e
Won't hammer somthing into it damage the cover of the case? I guess the plug is aluminum, right?
What is a triple square socket? Never mind, I googled it....
Can you guys see the picture now?
as350b3e is offline
post #5 of 21 Old 05-01-2013, 04:19 PM
ChrisHager
Administrator
ChrisHager's Avatar
What billzcat1 said...
You could also attempt to weld a nut on top of the plug. After a good weld, remove the plug with a socket.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is online now
post #6 of 21 Old 05-01-2013, 04:24 PM
Upside
I can see the pic now, might have been related to me being on the mobile site. As Billz Said try tapping in the next size larger bit and applying heat. I've also had luck using a reversing impact drill with a bit to back these out.
Upside is offline
post #7 of 21 Old 05-01-2013, 04:24 PM Thread Starter
as350b3e
I understand but there are hairline cracks around the base of the plug, worried I will break the cover.......
as350b3e is offline
post #8 of 21 Old 05-01-2013, 04:32 PM
lazyWJ
2006 XK Commander
Buy a 3/8" drive hex bit, tack weld it into the plug. Similar to the nut idea, but gives you more room to play. The cracks don't look significant to me.
2004 Imola BMW ZHP
2006 Commander Limited Hemi QD2
"Bought, Not Built"
lazyWJ is offline
post #9 of 21 Old 05-01-2013, 05:01 PM Thread Starter
as350b3e
Ok, thanks I will wait with this since I have to drive the WJ next week 500km to catch a plane to Europe, can't miss my flight!!!!
I have no welding equipment nor a torch and the shop rate is C$200 where I live, sucks I know.......
as350b3e is offline
post #10 of 21 Old 05-01-2013, 05:04 PM
USFORCES
It don't look stripped to me, sure your using the correct allen wrench?
Anyhow yeah I like the welding idea better...
04 Overland on 33's, Lift & tires= 8" over stock.
USFORCES is offline
post #11 of 21 Old 05-01-2013, 06:14 PM Thread Starter
as350b3e
Yeah I was, 10mm Allen. The drain plug fits perfectly.
as350b3e is offline
post #12 of 21 Old 05-01-2013, 06:42 PM
dagmando
You need a "Hanson Hex Head Multi-Spline Screw Extractor" size: 7/16. It is a stubby reverse thread extractor that with a 16mm socket and breaker bar will remove the plug easily. I just did it last fall. Use a hammer to lock it into the stripped hole and twist it out. Use my description and search Amazon. I bought mine for $11 shipped.
2002 WJ Laredo 4.7 Select-Trac
dagmando is offline
post #13 of 21 Old 05-01-2013, 07:21 PM
FlyRLo
In a pinch you could grab some car batteries and make an instant spot welder (and yes this does work)
http://www.ehow.com/how_4857206_spot...r-battery.html
FlyRLo is offline
post #14 of 21 Old 05-01-2013, 07:32 PM Thread Starter
as350b3e
Thanks FlyRLo, but I think I go with dagmando's solution or remove the cover since i want to stop the leak from the Transfer case.
Kind of look forward to work on the transfer case!
as350b3e is offline
post #15 of 21 Old 05-01-2013, 07:44 PM
js12278
IMO, those do not look like hairline cracks. They appear to be casting marks. I would suggest the ez out idea as well. If that doesn't work, spot weld the 10mm hex key in there. If you can't spin the hex key because of space limitations, cut off the excess and use a socket to back it all out.
js12278 is offline
