Trans Cooler Line Help Please - JeepForum.com
post #1 of 4 Old 01-21-2012, 07:36 PM Thread Starter
delkin
Im replacing the Rad in my 99 4.7 and I broke the transmission line that screws into the top of my rad. I cant find a replacement anywhere for it since I do not have the exterior trans cooler that apparently most of the other WJs come with since that is what the dealer keeps trying to sell me. Has anybody tried to replace this line and know the part number or where I can find it at? Any advice is welcome. Thanks
delkin is offline
post #2 of 4 Old 01-21-2012, 07:47 PM
bds5
Just buy an AfterMarket Cooler and Install it, Forget about the Stock setup.
bds5 is offline
post #3 of 4 Old 01-21-2012, 09:01 PM
allenrotstein
Here is the parts list for your 4.7 engine cooling system.
Does it help?
Grand Cherokee 99-04 WJ Service Manual:
Grand Cherokee 05-08 WK Service Manual: http://www.mediafire.com/?4q51ake1023nlb6
allenrotstein is offline
post #4 of 4 Old 01-22-2012, 08:46 AM Thread Starter
delkin
If you look closely at the line that leaves the bottom end of the transmission, I need the metal tube that goes into the radiator from that line. In the pic above it shows that it goes from the number six hose up the side of the rad and around the front to the external trans cooler then it will loop back around and go into the top port on the rad and then go out the bottom port and back to the trans. Or maybe I got that completely backwards. I dont know which direction the trans fluid flows. I think it helps to look at radiator parts instead of transmission parts.
delkin is offline
4.7 aux trans cooler 03svt4life WJ Grand Cherokee Forum 6 07-16-2011 08:30 PM
01 4.0 trans cooler hoyt5885 WJ Grand Cherokee Forum 2 06-01-2011 07:28 PM
Trans cooler which one to go with? shaunnj007 WJ Grand Cherokee Forum 2 01-19-2011 04:12 PM
wj trans cooler TheBoss WJ Grand Cherokee Forum 14 07-16-2010 08:45 AM
