tranny isnt shifting out of first HELP - JeepForum.com
post #1 of 18 Old 01-29-2011, 12:16 AM Thread Starter
JerzeyBoyWJ
2003 WJ
alrighttt well heres my story of what happened tonight
so i was a my buddies house and we decided to do a little off roading at the sand pit.. well started up the jeep and left to go to get gas while leave his driveway i went to pull out and it felt like it was sputtering and not getting enough fuel or something was clogged..we got to wawa and i got some gas then we started driving to the pit ..once again while i was pulling out it was acting like something was clogged then i started thinking my injector failed..
so i kept driving and we go to the pit found some snow ..drifted a little and did some donuts and it was driving completely normal
then we had our fun in the pit and i had no problems
but then when i got on the road it started to act up again
so i put the jeep to the floor hoping to clear some **** out
but that didnt work out too well
then my jeep decided "hey lets shake when you give me gas"
so that made me think it was my torque converter..
then i tried shifting my jeep manually listening to the rpms going from
1...2....D
then my jeep shifted perfect but i soon as i shifted into D she didnt go into overdrive and just stayed in a high rpm.. and wouldn't downshift so i drove to wawa shut her off and let her sit for a bit
15 mins later i decided to try to make it home
and found out my jeep didnt wanna go home
so while she was in drive she went into neutral while it said i was in drive
then i pulled over put her in park and then manually shifted again but this time when i went from 1st and then clicked to 2nd it stayed in first gear
as a result i had to drive all the way to my mechanic on the shoulder in first gear .. and it took foreverrrrr
DOES ANYONE KNOW WHAT MY PROBLEM IS !!!!
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
post #2 of 18 Old 01-29-2011, 01:58 AM
ras2001wj
ras2001wj's Avatar
you more than likely busted a snap ring. You more than likely need a rebuild or a junkyard tranny. Sorry to be the one to tell you this.
Rick
2001 WJ Laredo 4.0
2" BB
245/75R16
Ron Paul
2012
"Freedoms Popular"
ras2001wj is offline
post #3 of 18 Old 01-29-2011, 09:09 AM
JohnnyS
2011 JK Wrangler
Did your check engine light go on? Are you getting a transmission code? Did it ever just go into limp mode, just keeping you in 3rd gear? How many miles on the transmission? While driving in first, did you try turning the key to off, put it in neutral, turn key on and put it in drive...and did it go into drive or stay in 1st gear? Before I had my transmission rebuilt, mine did some odd things.
2011 JKU Rubicon, 2005 Hayabusa....I get to where I need to go, One way or Another.
JohnnyS is offline
post #4 of 18 Old 01-29-2011, 12:54 PM Thread Starter
JerzeyBoyWJ
2003 WJ
just went to check the codes it threw and here they are...P0123 and P0720
post #5 of 18 Old 01-29-2011, 02:27 PM Thread Starter
JerzeyBoyWJ
2003 WJ
bump
post #6 of 18 Old 01-29-2011, 03:25 PM
ras2001wj
ras2001wj's Avatar
Originally Posted by wjjeeps.com
P0123
Throttle/Pedal Position Sensor/Switch A Circuit Intermittent
Throttle position sensor input above the maximum acceptable voltage. Follow all appropriate diagnostics for the fault that is present. Prior to replacing parts, check all connectors between the speed control switch and the PCM for moisture Internally the PCM uses the same A/D (analog to digital) converter for TPS voltage as it does for the speed control switch sense. If the v-37 circuit has voltage bleed over from another source, a code of TPS Shorted to voltage may be set in the PCM. The DN model equipped with rear heat option, has an external water pump to circulate coolant to the rear heater. If you find coolant in the bulkhead connector, the likely cause would be a leaking coolant pump. Pump should be replaced if found leaking. If the code sets when the A/C is turned on go right to the bulk head connector and check for moisture. Check for a shorted clock spring causing the speed control 5 volt feed to be shorted to power.
Rick
2001 WJ Laredo 4.0
2" BB
245/75R16
Ron Paul
2012
"Freedoms Popular"
post #7 of 18 Old 01-29-2011, 03:26 PM
ras2001wj
ras2001wj's Avatar
P0720 (M)
Low Output SPD Sensor RPM Above 15 MPH
Output shaft speed is less than 60 rpm with vehicle speed above 15 mph (4-speed auto. trans. only).
Rick
2001 WJ Laredo 4.0
2" BB
245/75R16
Ron Paul
2012
"Freedoms Popular"
post #8 of 18 Old 01-29-2011, 06:19 PM
MStaffin
You blew your tranny man. Im pretty sure of it.
MStaffin is offline
post #9 of 18 Old 01-29-2011, 07:40 PM Thread Starter
JerzeyBoyWJ
2003 WJ
but my reverse still works.. thats whats got me confused
post #10 of 18 Old 01-29-2011, 08:04 PM
icecool742
man ! you in for fun!
my 04 did exactly same thing !!!!!!!!!! at 80k!
here's what I did and F.ed UP!
took valve body off cleaned it and but all back in . what I didn't see that I was missing check balls from valve body!
long story short, dont clean it ! dont rebuild it! if you can get cheap tranny get it! if not see if shot can replace sensors !
I end up getting rebuilt tranny from Arizona but I got wrong year! I guess shop didn't check vin !
after installing new tranny I had to order new valve body and sensors anyway for my 2004 .
if I had to do it again I would take it to dealer and it would be cheaper !
good luck dude!
icecool742 is offline
post #11 of 18 Old 01-29-2011, 09:17 PM
JohnnyS
2011 JK Wrangler
Go have your transmission rebuilt if u find its shot. Straight up its going to be about 2k give or take. If u order up a used one, that's what ur going to get and in time it will also explode. Find a good shop, with a good warranty. Better to reuse yours and put in new/ upgrade parts. Used may seem cheaper upfront at 1200 but then u pay freight, install, fluids and then u at same prices as just rebuilding yours. Unless ya know a used unit has been rebuilt, has 3 year warranty, etc..you may end up with another blown trans in about 10000 miles or less...maybe you will get lucky but luck doesn't seem to happen much these days to most folks.
JohnnyS is offline
post #12 of 18 Old 01-30-2011, 10:15 AM
MStaffin
Rebuild it man. Im doing my zj trail rig myself cause its a trail rig but when my wj gose shes getting rebuild at a shop. Ill have my trans dude do it so I know it wont be beep up.
MStaffin is offline
post #13 of 18 Old 01-30-2011, 03:59 PM
tim-tim
rebuild it or find a used one. my tranny went out on me with no signs of it going out. thankfully my reverse went out and i still had all my foward gears. your problem is in your overdrive housing. (the rear part of the tranny) anyway my experience was i changed out my filter and and fluid and after i dropped my trans pan i noticed a pice of snap ring stuck to the magnet. so i knew mine was goin to go i just drove it til it broke. you can drop your pan and see if there are anything there thats not supposed to be there. also i drove mine for 6 months after i changed my filter and fluid.
tim-tim is offline
post #14 of 18 Old 01-30-2011, 04:38 PM Thread Starter
JerzeyBoyWJ
2003 WJ
ok guys i really appreciate all of your opinions... im going to have my shop look at it tomorrow and get an estimate on how much hes going to charge if its way too much im going to take it some place else and help the shop with rebuilding my tranny .. i think it would be a good project for me to learn since im only 18.. i put to much time into my jeep to let a tranny stop my build
post #15 of 18 Old 01-30-2011, 06:24 PM
92rslt1
probably the tps or vss. they dont know when to shift when either of these two sensors go bad.
02 overland, bone stock
92rslt1 is offline
HELP!! Shifting problems? flandaz13 WJ Grand Cherokee Forum 0 11-09-2010 07:15 PM
my 4x4 isnt working any ideas??? happy1426 WJ Grand Cherokee Forum 19 11-04-2010 03:44 PM
i promise this isnt another "clunk" thread patrick983 WJ Grand Cherokee Forum 14 09-19-2010 07:24 PM
Shifting problems. Rugaru WJ Grand Cherokee Forum 3 09-02-2010 06:12 AM
WJ Tranny: shifting problem during sharp turns JCDubya WJ Grand Cherokee Forum 7 08-05-2007 06:25 PM
