Trailer Hitches Interchangeable? - JeepForum.com
post #1 of 10 Old 12-20-2013, 07:53 PM Thread Starter
Blane11
Hello All. I come seeking knowledge.
I'm looking to put a towing package/trailer hitch on my 2000 jeep grand cherokee. Instead of buying a brand new one I decided to check out my local salvage yard. I found one on a 01 grand that appears to be stock for $33 and some change. Before I go back and take it off, does anyone know if it'll fit on my 2000 grand?
Also, anyone have experience removing/installing these? Level of difficulty?
Thanks.
Blane11 is offline
post #2 of 10 Old 12-20-2013, 07:56 PM
gcjeeping
gcjeeping's Avatar
99-04 will fit any and all. Be aware thgas tank skid witch holds the gas tank is sandwiched hitch and uniframe. SEE PDF BELOW.
Get the trailer harness too.
Get the bumper bezel also. Although Limited and Laredo bezels are slightly different but can work on either.
Easy. If you live in the rust belt pre soak bolt for week. A floor jack is a big help. Use it to hold gas tank skid and tank up when you remove the skid bolts that are used for the hitch. Tank skid only has 3 bolts on each side but hitch uses 4 per side so get the bolts from the JY hitch so you have spares.
Read all these.
http://www.wjjeeps.com/pdf/trailer_hitch_install.pdf
http://www.wjjeeps.com/pdf/trailer_harness_install.pdf
http://www.wjjeeps.com/trailer.htm
_____________
gcjeeping is offline
post #3 of 10 Old 12-20-2013, 08:11 PM Thread Starter
Blane11
Thanks gcjeeping. That's a big help.
I don't have a week, however. I'm going back on Sunday to attempt the removal. Some lubricant and a socket set is all I have to get the job done. We'll see how it turns out.
Again, thanks for the help.
Blane11 is offline
post #4 of 10 Old 12-20-2013, 08:34 PM
gcjeeping
gcjeeping's Avatar
The pre soak was more for your jeep. Like I said depends on if you live in the rust belt you may snap some bolts off the donor vehicle. If the bolts are rusted or bind you gunna have a good work out.
Hitch...
A 1/2" long handle ratchet and breaker bar. A 6" or longer extension. Instructions say 13mm, 15mm and 18mm sockets. I would have same sizes in wrenches too.
Bumper cover(if you decide to remove it)...
Phillips screw driver and common screwdriver. Needle nose and diagonal (dikes) also.
Bezel...
Long common screw driver and a good sharp putty knife. You will need to break the welded plastic rivets that hold it to the bumper.
Harness...
Phillips screw driver and possible small sockets (7mm or so) for the hitch 7 way plug receptacle on the hitch. I have found the 4 screw to be either phillips or socket.
Also if for some reason the donor jeep is missing the 7 way plug receptacle you can get one off a Dodge truck. Same plug.
_____________
post #5 of 10 Old 12-20-2013, 08:50 PM Thread Starter
Blane11
I just read over your material gc. The installation may be tougher than I anticipated, but I'm gonna give it a whirl.
Looks like I'll have to take the bumper off. That correct? Will I have to have the bumper bezel from the donor?
Blane11 is offline
post #6 of 10 Old 12-20-2013, 08:57 PM
gcjeeping
gcjeeping's Avatar
If you can get the parts off a jeep you should be able to put them on another.
You can get the hitch off without taking the bumper off. But your jeep if it does not have the cut out already will need it cut out ad this may be easier for you with the bumper off. Some bumpers on the backside have guide lines for cutting it for the bezel others don't. Your decision on how you cut it. The bezel will hide some bad cutting though.
You only need the bezel if you want a factor looking instal on your jeep. You can reattach it with body fasteners or screws.
_____________
post #7 of 10 Old 12-22-2013, 04:13 PM Thread Starter
Blane11
If you around GC, I've successfully removed the hitch at the salvage yard and am now getting ready to remove my rear bumper so I can make a cut and install the hitch.
Questions: (I looked on the website you gave but didn't see anything relating to rear bumper removal)
-I see 4 plastic pins on the bumper that need to be removed. Before I just go to tugging at them, should they just pop out and be good to pop back in?
-I see the plastic rivets (?) around the wheel wells - same question as above.
-I've got the 2 star drive screws out. Am I missing any fasteners?
Edit:
Ok so i got all of the push pins out (8). And, the plastic rivets (6). What am I missing?
Blane11 is offline
post #8 of 10 Old 12-22-2013, 06:15 PM
gcjeeping
gcjeeping's Avatar
Read this thread. Has pics too...
http://www.jeepforum.com/forum/f13/r...9-help-136024/
_____________
post #9 of 10 Old 12-22-2013, 06:59 PM Thread Starter
Blane11
yea, I cracked the bumper a little by the wheel well on accident. But I can now see the SOBs that are giving me trouble. The bumper seems to be held to the body on the track by 2 metal rivets. Not sure what to do about those, so I guess Ima have to make a cut with the bumper on and get a bezel at a later date.
Blane11 is offline
post #10 of 10 Old 12-22-2013, 08:11 PM
gcjeeping
gcjeeping's Avatar
Should be no metal rivets.
Here are a couple vids...
_____________
