Trailer Hitch Install - JeepForum.com
post #1 of 2 Old 06-23-2010, 06:42 PM Thread Starter
SGT Superman
SGT Superman's Avatar
Hello,
I have a 6 cylinder 2000 WJ and I want to install a trailer hitch on if for camping.
I want to use a hitch from an 8 cylinder WJ, but would like to know if there are any issue with this, I would think that it should be a straight swap. Just have to cut the bumper a bit.
If anyone has done this and has some tip it would be great.
Thanks,
Now you know, and knowing is half the battle. G.I. Joe!
Green Jeep Club Member #174
GO COUGS!
SGT Superman is offline
post #2 of 2 Old 06-23-2010, 08:32 PM
MudPit
Same part OE or aftermarket.
If OE, you would only need to cut for the bezel installation.
If aftermarket... Install is easy, unless you have skid plates. I have the Curt and it required 3 people to set straight because the #%# plate kept sliding.
__________________________________________________ __________________________
"I let the dogs out.
MudPit is offline
What does your trailer hitch install look like? grandcherokee12 ZJ Grand Cherokee Forum 3 02-15-2010 06:40 PM
Install factory trailer hitch info kevin1977 WK Grand Cherokee & XK Commander Forum 18 09-10-2009 08:19 AM
02 Gc Trailer Hitch Install And Wiring Install evanlaczi ZJ Grand Cherokee Forum 2 03-02-2009 10:10 PM
trailer hitch install indredsnake99 ZJ Grand Cherokee Forum 2 02-17-2009 12:43 AM
Trailer Hitch det69 ZJ Grand Cherokee Forum 6 10-28-2004 11:17 AM
