Track Bar Pop. New bolts , bushings, both? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Track Bar Pop. New bolts , bushings, both?
Rough Country Deals at JeepHut.comSave at JeepHut on Smittybilt Soft topsUp to $75 Cash Back on Your ARB Fridge Freezer Purchase
Unread 08-19-2014, 07:48 PM   #1
akoutdoors1
I have a new IRO adjustable track bar on my 2000 WJ. Problem is, the bolts are too small for the bushing Inside Diameter, so it pops. Who else has had this problem? How did you remedy it?
akoutdoors1 is offline   Reply With Quote
Unread 08-19-2014, 09:25 PM   #2
Ben_dover4dover
I like to smell tires
Ben_dover4dover's Avatar
pretty common from what i understand.
i've heard getting a bigger bolt or welding a washer the size of the bolt over the wobbled out hole .
Id check to see if you can locate a bigger bolt
http://www.jeepforum.com/forum/f22/l...ld-wj-2641090/I have a Jeep. There are things done to it
Ben_dover4dover is offline   Reply With Quote
Unread Yesterday, 09:44 PM   #3
akoutdoors1
I'll have to crawl under it again to check, but it seems like welding a washer would fix it. Thanks man.
Otherwise, just getting a bolt would be simpler (I don't have a welder) anybody got specs on a replacement bolt?
Unread Today, 07:03 PM   #4
Ben_dover4dover
i had to get one, and i just took part of my track bar to lowes and test fitted different bolts.
other people may know the exact size, i cant remember what i got.
