Track bar bolt uprade size question - JeepForum.com
post #1 of 4 Old 06-24-2013, 07:41 PM Thread Starter
Woliwi
I have searched....... and have come up with some different sizes and types.
I am installing a JKS adj. Track bar with KOR bushings to my 2004 WJ.
What size upgraded bolts do I need? Washers too?
Thanks, Woliwi
Woliwi is offline
post #2 of 4 Old 06-24-2013, 07:42 PM
narnwv
narnwv's Avatar
Body side or axle side?
The axle side is M12x1.75, with a solid, non-threaded shaft.
The body side will depend on the nut, and how wallowed out the hole is.
~Aaron
narnwv is offline
post #3 of 4 Old 06-24-2013, 10:32 PM Thread Starter
Woliwi
Thanks,
axle side....check
body side....?
If the nut is good...?
Mopar replacement size? or drill out nut for ? size replacement bolt.
Woliwi is offline
post #4 of 4 Old 06-25-2013, 06:10 AM
dcorn
Measure the hole in the metal sleeve of the KOR bushings. You'd have to drill that out too if you got a bigger bolt.
2014 Jeep Grand Cherokee Summit
dcorn is offline
