TPS Where is it? How to Replace? - JeepForum.com
post #1 of 13 Old 01-16-2008, 04:25 PM Thread Starter
86Spider
86Spider's Avatar
My check engine light came on and I had the guy at O'Rielly check it.
It came up with a P0122 Throttle/Pedal Position Sensor/Switch A Circuit Low Input.
So, where is this thing located on a 2003 Gr Cherokee 4.0? What's it look like and do I have to adjust the new one when I get it??
Thanks-
Mark in Kentucky
93 YJ 4cyl 5 spd
4" RC Lift, 33x12.50 MT's
86Spider is offline
post #2 of 13 Old 01-16-2008, 04:51 PM
rm2001wj
rm2001wj's Avatar
TPS is easy to find and replace. It does not need any adjusting. Attached are a couple of pages from the FSM to help locate it and replace.
rm2001wj is offline
post #3 of 13 Old 01-16-2008, 05:13 PM
greasefingers
greasefingers's Avatar
1994 ZJ
I do not know about newer Jeeps, but if it has Drive-by-wire then it might have both a pedal position sensor and a TPS (throttle position sensor)?
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #4 of 13 Old 01-16-2008, 07:47 PM Thread Starter
86Spider
86Spider's Avatar
rm2001wj: You're the man!! Thanks for the pictures, that's just what I needed!
greasefingers: They only came up with one part number at O'Rielly, but the manager there thought there should be a sensor at the pedal.....hmmmm.
Mark in Kentucky
93 YJ 4cyl 5 spd
86Spider is offline
post #5 of 13 Old 01-17-2008, 02:48 PM Thread Starter
86Spider
86Spider's Avatar
Today the Check Engine Light is off.................
I think I will go ahead and get the TPS from O'Rielly, I think he said it's about $35, and toss it in the glovebox or the back netting of the Jeep and replace it when it gets a bit warmer or when it fails!!
Mark in Kentucky
93 YJ 4cyl 5 spd
86Spider is offline
post #6 of 13 Old 12-09-2010, 02:43 PM
orb
2003 WJ
So did the light ever come back on? I'm getting the same code (p0122) on my 2003 WJ. Anyone else had this code and a new TPS resolved it?
orb is offline
post #7 of 13 Old 02-13-2011, 03:29 PM
35charlie
I had the p0122 code come on and go away 2x in a few weeks' time. I changed the TPS a few weeks ago and no more codes.
However, it's occasionally idling at 1100 RPM instead of the normal ~750. Restarting sometimes corrects the idle. I've checked the intake and water temp sensors with OBD and by pulling the connectors while running (causing the engine to speed up & set codes) and they all checked out ok. Anyone have any suggestions? The new TPS measures 0.5V at idle and 3.6V at WOT.
35charlie is offline
post #8 of 13 Old 02-13-2011, 03:56 PM
rm2001wj
rm2001wj's Avatar
Try cleaning the IAC (idle air control) solenoid/motor, or consider replacing it if cleaning doesn't solve the problem. Although some sources (like the Haynes Manual) will say differently, your TPS voltages are typical and indicate no problem there.
It wouldn't hurt and is usually helpful if you supplied info on your Jeep, in the post or by filling out the profile.
rm2001wj is offline
post #9 of 13 Old 02-14-2011, 10:35 AM
35charlie
Thanks. I have a 2002 4.0L WJ. I guess I should have said that and I've updated my info now.
After I posted and did some more googling my next thing was going to be to clean the IAC. The throttle body is pretty black below the butterfly.
A couple other pieces of info:
The idle does run up and down when I cycle the A/C (even from the higher starting point). It acts like the IAC is at least moving but perhaps it's moving to/from the wrong base point.
I connected a OBD scan guage and was monitoring the TPS when it was at high idle. I need to reconfirm but I'm pretty sure it was at 14 at idle when it was normally at 10. Does the IAC actually move the throttle or just bypass the butterfly?
post #10 of 13 Old 02-14-2011, 11:28 AM
melk
It you remove the IAC from the TB you will see there is a passage that bypasses the butterfly. Be sure to clean in there too.
melk is offline
post #11 of 13 Old 11-10-2011, 01:01 AM
sbotzer
Hey,
I am looking to know where the TPS is on the 2008 Diesel JEEP GRAND CHEROKEE, 3.7L V6.
Thanks,
SHay
sbotzer is offline
post #12 of 13 Old 11-10-2011, 11:43 PM
35charlie
I don't know where it is on the diesel but I realized I never updated my high idle issue. It turns out there was a rotten vacuum hose that I finished off when I changed the TPS. It's the u-shaped one that stands in the air near there. When was changing the TPS, my arm rested on it and the ends split. So I was fighting an intermittent vacuum leak. New hose = problem solved!
post #13 of 13 Old 03-20-2016, 05:26 PM
Nishbot
Did you end up figuring this out?
Nishbot is offline
Replace ZJ with WK? Dirtyriders110 WK Grand Cherokee & XK Commander Forum 24 10-26-2009 07:31 PM
Have to replace AC evap what else should I replace? crashcraddock ZJ Grand Cherokee Forum 17 06-28-2009 06:55 AM
What should i look to replace: ncbimma ZJ Grand Cherokee Forum 0 01-08-2009 07:53 PM
For those that have had to replace their 4.7 neodamonkey ZJ Grand Cherokee Forum 9 05-09-2008 11:34 AM
Replace Gas Cap? wreck76 ZJ Grand Cherokee Forum 1 06-29-2006 05:59 AM
