Towing a Grand - JeepForum.com
post #1 of 3 Old 10-12-2003, 11:25 AM Thread Starter
Ross
Towing a Grand
My book is al ready packed.
I need to tow my grand 2001, select trac, behind a uhaul truck. Should I put it up on a trailer or use the auto dolly. I will be towing it about 1700 miles. If I use the dolly and leave the back wheels down I know I put the tcase in neutral but where do I put the trans. Does it need to be in gear to keep things lubed or not.
Thanks,
Ross
01 TJ,33X12.5Flaken WP ATs,Winch, ARBs F&R, belly up, some armor,4.0,5spd
Ross is offline
post #2 of 3 Old 10-12-2003, 01:24 PM
Harald
Thanks,
Ross
Look at http://www.jeep.com/4x4/index.html?c...epage&type=tab
If you put TC in neutral, shaft going from automatic trans to TC will not move. So it does not matter in what gear you put the trans. In general, lube pump on car trans is diven by the engine. There are only a few marine trans where lube pump is driven by outgoing shaft...
1700 miles is a bit to drive. Think it would be most convenient to have the whole thing on a trailer. And the trailer will probably have brakes as well.
Harald is offline
post #3 of 3 Old 10-15-2003, 09:13 AM
shylow
shylow's Avatar
If you leave the back wheels on the ground, disconnect the drive shaft. Thats what i did. The place that rents the u-haul should tell you to do the same thing.
shylow is offline
Towing capacity of a 98 Grand? palmaceae ZJ Grand Cherokee Forum 18 12-21-2016 02:38 AM
towing a grand Jeep2003 ZJ Grand Cherokee Forum 8 10-02-2008 09:09 PM
Towing With My 4.0l Grand Cherokee 98LAREDO ZJ Grand Cherokee Forum 3 04-01-2008 11:19 PM
96 Grand Cherokee Towing jplush76 ZJ Grand Cherokee Forum 4 03-01-2004 11:59 AM
Grand Cherokee and Towing pierre_piav ZJ Grand Cherokee Forum 3 06-26-2002 09:51 AM
