12-25-2011, 12:14 PM
#1
I had been thinking of installing front tow hooks. I looked at the frame behind the bumper where the tow hooks would bolt to (according to the tow hook kits) and it sure doesnt look very strong. I have an '02 grand cherokee limited.
Is this for sure a good location to install hooks to?
12-25-2011, 12:21 PM
#2
Real Jeeps have dents
Originally Posted by meopilite
...Is this for sure a good location to install hooks to?
It is the location that the Jeep engineers designed and had built to handle the extra stresses of tow hook use, so it has to be good.
Where else, or how else, would you attach tow hooks ?
. Progressive Liberalism: Bringing you new ideas so wonderful, they have to include mandatory participation ......
Originally Posted by Ronald W. Reagan
Government is not the solution to our problem; Government is the problem.
12-25-2011, 01:27 PM
#3
Factory tow hooks with the factory brackets are a great idea. If you are trying to mount the regular hooks that you can buy for cheap to the uniframe it is a bad idea. The brackets properly distribute the load, if you mount hooks with two bolts to the frame they will rip straight out
12-25-2011, 02:06 PM
#4
If strength is your issue, these should work for you.
http://www.saguaro4xcomponents.com/i...5ai3u48tj8ar64
They are rather pricey, but you hear nothing but good things about them.
David_Silver WJ Laredo 4.0
2"BB with Pro Comp MX6 shocks on 245/75/16 Goodyear Duratracs
OME SS_IPF series 868 lights
Plus a few other junkyard goodies...
12-25-2011, 08:44 PM
#5
They are way high priced. I made my own out of 1/4" steel with hooks for less than $25. It was $18 for both hooks.
MY PITBULL IS SMARTER THAN YOUR HONOR STUDENT
12-25-2011, 08:45 PM
#6
Originally Posted by dlundblad
Those do look nice and I've heard of people actually bending the stock brackets a bit, but that doesn't fix his concern. He's concerned with where they actually mount to on the frame. But as others have said the engineers designed the Jeep to handle loads there and I have yet to see anyone with issues on the frame side of the tow hooks. The stock mounting location works fine and if you are concerned with the integrity of the stock hooks and mounts that aftermarket option looks like it would work well. I've also seen several people speak highly of Rusty's tow hook solution.
Eric - '02 Laredo Grand Cherokee
Build Thread
12-26-2011, 09:21 AM
#7
Could you post pics? Have you ever used them yet?
01-01-2012, 05:33 PM
#8
01-01-2012, 05:38 PM
#9
Nice. Thanks
01-01-2012, 07:08 PM
#10
These look like it will take a hell of alot to rip them off the frame. However I don't see that skinny little piece the hooks actually mount to holding up well, especially taking a hard pull from the side.  They do look good though.
2004 WJ Laredo-selectrac 242-I6- Custom XJ intake w/Amsoil cone filter- PSC HD Pump & Res- PSC ported box- B&M trans cooler- B&M PS cooler- Custom chevy 1 Ton over the knuckle steering- Rough Stuff 1 Ton tierod & draglink ends- Saguaro 4x4 Front 3/4" shackles, Rear hitch & Warn 3/4" shackle-Mopar Front skid,Gastank skid -IRO TC skid- RRO super sliders- 6.5'' IRO critical path lift -IRO extended rear arms-Bilstein 5125 shocks -IRO F&R 6.5'' Bump stops-Carolina drive shaft-16x7 black soft 8's - 34'' Super swampers-Yukon 4.11 gears -Ultimate RCV shafts - LockRight Locked ECGS bolt in rear D60 -35 spline Chomloy shafts -BTF HD diff cover -IRO Adj A-arm-OX Locked super D30 -OX HD diff cover -OX drive away lock-Rock Krawler d30 truss-Stillen rotors & Matrix pads-JKS Adj Track Bar-JKS Quicker discos -Relocated OME SD-40 Steering Stabilizer-BDS stabilizer brackets-Relocated washer bottle-Removed rear sway bar-Cobra CB-TomTom one XL navi-alpine deck
Still to come: Flowmaster 50suv
October 2011 GCOTM Winner
Some of my videos: http://www.youtube.com/user/LockedWJ?feature=mhee
Originally Posted by billyjp2
I burnout on puppies and kittens
Originally Posted by vwmaniacx
Lets not and say we didn't.
02-08-2012, 09:12 PM
#11
02-08-2012, 09:45 PM
#12
I have only needed them 2 times and worked great. As you see I used grade 8 hardware. And they have 3 bolts on each side of the body.
I would pay you to make these for me and it would still be cheaper than the price I have found them online! They look great and strong.
02-08-2012, 09:49 PM
#13
I bolted on a cheap hf hook with a backing plate as a temp while my bumper is off and i have yet to screw anything up.
02-08-2012, 09:52 PM
#14
^^^ wow. I have a feeling something else is going to fail before those mounts. Nice work.
Black 2004 Overland - OME HD springs, Bilstein 5100 shocks, JKS Quick Disco's, JKS Adj. Track Bar, IRO Rear Sway Bar Links, Moog steering upgrades, Roof Rack, Audio Aux Input addition, DuelerRevo2's
02-08-2012, 11:05 PM
#15
JRobes, Thank's.
